I am trying to run RTX Lidar tutoria, but the following sensor extension loading error appears during the simulation app startup which doesn’t allow me to use RTX lidar in the sim context.
[22.405s] [ext: omni.kit.window.title-1.1.3] startup
[22.410s] [ext: omni.replicator.composer-1.2.17] startup
[22.509s] [ext: omni.replicator.isaac-1.11.3] startup
[22.690s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[22.706s] [ext: omni.kit.viewport.menubar.camera-105.1.9] startup
[22.731s] [ext: omni.isaac.sensor-9.11.1] startup
2024-06-03 08:56:37 [22,591ms] [Error] [carb.scripting-python.plugin] UnicodeDecodeError: ‘cp949’ codec can’t decode byte 0xe2 in position 1278: illegal multibyte sequence
At:
C:\Users\mm\AppData\Local\ov\pkg\isaac_sim-2023.1.1\kit\python\lib\json_init_.py(293): load
c:/users/mm/appdata/local/ov/pkg/isaac_sim-2023.1.1/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/menu.py(204): init
c:/users/mm/appdata/local/ov/pkg/isaac_sim-2023.1.1/exts/omni.isaac.sensor/omni/isaac/sensor/scripts/extension.py(31): on_startup
C:\Users\mm\AppData\Local\ov\pkg\isaac_sim-2023.1.1/kit/kernel/py\omni\ext_impl_internal.py(164): _startup_ext
C:\Users\mm\AppData\Local\ov\pkg\isaac_sim-2023.1.1/kit/kernel/py\omni\ext_impl_internal.py(224): startup
C:\Users\mm\AppData\Local\ov\pkg\isaac_sim-2023.1.1/kit/kernel/py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
C:\Users\mm\AppData\Local\ov\pkg\isaac_sim-2023.1.1/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(304): _start_app
C:\Users\mm\AppData\Local\ov\pkg\isaac_sim-2023.1.1/exts/omni.isaac.kit\omni\isaac\kit\simulation_app.py(192): init
C:\Users\mm\AppData\Local\ov\pkg\isaac_sim-2023.1.1\standalone_examples\api\omni.isaac.sensor\rotating_lidar_rtx.py(16):
2024-06-03 08:56:37 [22,594ms] [Error] [omni.ext.plugin] [ext: omni.isaac.sensor-9.11.1] Failed to startup python extension.
[23.313s] [ext: omni.kit.viewport.menubar.render-105.1.1] startup
[23.328s] [ext: omni.kit.viewport.menubar.settings-105.0.9] startup
[23.358s] [ext: omni.replicator.replicator_yaml-2.0.4] startup
[23.410s] [ext: omni.rtx.settings.core-0.5.13] startup
[23.429s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[23.439s] [ext: omni.isaac.quadruped-1.4.1] startup
[23.491s] [ext: semantics.schema.property-1.0.2] startup
[23.500s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[23.500s] [ext: omni.isaac.scene_blox-0.1.0] startup
[23.510s] [ext: omni.importer.urdf-1.6.1] startup
[23.622s] [ext: omni.importer.mjcf-1.1.0] startup
[23.664s] [ext: omni.kit.window.stats-0.1.4] startup
Strange thing is that the sensor extension loading error does not appear when opening isaac sim from omniverse launcher, where I can use the RTX lidar without any error. I double checked from windows>extension and the sensor extension is loaded well…
Can anyone give me some suggestions?
