Hello Everyone,
when i try to compile .cu files in VS 2010 Professional, i get the following error:
“Error 2 error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v5.5\bin\nvcc.exe” -gencode=arch=compute_10,code="sm_10,compute_10" --use-local-env --cl-version 2010 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v5.5\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v5.5\include” -G --keep-dir Debug -maxrregcount=0 --machine 32 --compile -cudart static -g -DWIN32 -D_DEBUG -D_CONSOLE -D_UNICODE -DUNICODE -Xcompiler “/EHsc /W3 /nologo /Od /Zi /RTC1 /MDd " -o Debug\kernels.cu.obj “\cr.uni-frankfurt.de\homes\stelzer\s1378004\documents\visual studio 2010\Projects\cudaprojekt12\cudaprojekt12\kernels.cu”” exited with code 2."
The target file is located in “C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\BuildCustomizations\CUDA 5.5.targets”, line 592 column 10
Cuda and NSight seem istalled correctly, and i can acces the CUDA- and NSight Tools in VS 2010
Has someone an idea where this comes from and how to fix it?
Thank you!
Chenya
