WayneWWW:
dmesg
finagle@ubuntu:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5496-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jun 11 16:07:05 PDT 2024
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[ 0.000000] pcpu-alloc: s57816 r8192 d32296 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: enabling workaround for Spectre-BHB
[ 0.000000] CPU features: enabling workaround for ARM erratum 1742098
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29520(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3560056K/4159488K available (15486K kernel code, 2982K rwdata, 6716K rodata, 8640K init, 614K bss, 124296K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0x (ptrval) - 0x (ptrval) ( 15488 KB)
[ 0.000000] .rodata : 0x (ptrval) - 0x (ptrval) ( 6784 KB)
[ 0.000000] .init : 0x (ptrval) - 0x (ptrval) ( 8640 KB)
[ 0.000000] .data : 0x (ptrval) - 0x (ptrval) ( 2983 KB)
[ 0.000000] .bss : 0x (ptrval) - 0x (ptrval) ( 615 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001802] Console: colour dummy device 80x25
[ 0.001812] console [tty0] enabled
[ 0.001818] bootconsole [uart8250] disabled
[ 0.001839] kmemleak: Kernel memory leak detector disabled
[ 0.001860] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.001872] pid_max: default: 32768 minimum: 301
[ 0.002351] Security Framework initialized
[ 0.002596] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002601] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003786] ftrace: allocating 47298 entries in 185 pages
[ 0.182695] sched-energy: CPU device node has no sched-energy-costs
[ 0.192266] ASID allocator initialised with 65536 entries
[ 0.220165] tegra-id: chipid=22117.
[ 0.220178] tegra-id: opt_subrevision=0.
[ 0.220196] Tegra Speedo/IDDQ fuse revision 4
[ 0.220201] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.220205] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.220211] Tegra: CPU Speedo Value 2083, SoC Speedo Value 1989, GPU Speedo Value 2088
[ 0.220253] Tegra: CPU IDDQ Value 1964, SoC IDDQ Value 2192, GPU IDDQ Value 2680
[ 0.220282] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.220297] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.220305] DTB Build time: Jun 11 2024 16:09:23
[ 0.269122] CPU1: Booted secondary processor [411fd071]
[ 0.301009] CPU2: Booted secondary processor [411fd071]
[ 0.332992] CPU3: Booted secondary processor [411fd071]
[ 0.333090] Brought up 4 CPUs
[ 0.333096] SMP: Total of 4 processors activated.
[ 0.333104] CPU features: detected feature: 32-bit EL0 Support
[ 0.333345] CPU: All CPU(s) started at EL2
[ 0.333365] alternatives: patching kernel code
[ 0.341790] devtmpfs: initialized
[ 0.380468] Initilizing CustomIPI irq domain
[ 0.380793] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.380817] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.393951] pinctrl core: initialized pinctrl subsystem
[ 0.394548] OS set in device tree is not L4T.
[ 0.395081] regulator-dummy: no parameters
[ 0.395344] Initializing plugin-manager
[ 0.395505] Plugin module not found
[ 0.395702] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[ 0.396239] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[ 0.396670] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[ 0.397428] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.397650] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.398266] node /plugin-manager/fragement@13 match with board >=3448-0002-300
[ 0.402158] NET: Registered protocol family 16
[ 0.403563] pstore: using zlib compression
[ 0.403609] console [pstore-1] enabled
[ 0.403613] pstore: Registered ramoops as persistent store backend
[ 0.403618] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.417141] cpuidle: using governor menu
[ 0.421421] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.423173] vdso: 2 pages (1 code @ (ptrval), 1 data @ (ptrval))
[ 0.423194] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.425760] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.428140] Serial: AMBA PL011 UART driver
[ 0.428683] tegra_powergate_init: DONE
[ 0.428697] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0002-p3449-0000-b00.dts
[ 0.428704] DTB Build time: Jun 11 2024 16:09:23
[ 0.430717] Tegra reboot handler registered.
[ 0.435299] iommu: Adding device tegra-carveouts to group 0
[ 0.435446] platform tegra-carveouts: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.435805] iommu: Adding device smmu_test to group 1
[ 0.435850] platform smmu_test: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.436668] mc: mapped MMIO address: 0x (ptrval) → 0x70019000
[ 0.436719] mc: mapped MMIO address: 0x (ptrval) → 0x7001c000
[ 0.436773] mc: mapped MMIO address: 0x (ptrval) → 0x7001d000
[ 0.436783] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.436804] mc-err: mcerr ops are set to t21x
[ 0.447227] iommu: Adding device 70090000.xusb to group 2
[ 0.447513] iommu: Adding device 70006000.serial to group 3
[ 0.447569] platform 70006000.serial: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.448002] iommu: Adding device 70006040.serial to group 4
[ 0.448259] iommu: Adding device 70006200.serial to group 5
[ 0.448450] iommu: Adding device sound to group 6
[ 0.448515] platform sound: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.449091] iommu: Adding device 7000d400.spi to group 7
[ 0.449429] iommu: Adding device 7000d600.spi to group 8
[ 0.449769] iommu: Adding device 50000000.host1x to group 9
[ 0.450033] iommu: Adding device 54080000.vi to group 10
[ 0.450455] iommu: Adding device 54600000.isp to group 11
[ 0.450715] iommu: Adding device 54680000.isp to group 12
[ 0.450982] iommu: Adding device tegradc.0 to group 13
[ 0.451035] platform tegradc.0: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.455239] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[ 0.455634] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.455955] iommu: Adding device tegradc.1 to group 14
[ 0.456004] platform tegradc.1: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.460156] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[ 0.460548] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.460838] iommu: Adding device 54340000.vic to group 15
[ 0.461041] iommu: Adding device 544c0000.nvenc to group 16
[ 0.461257] iommu: Adding device 54500000.tsec to group 17
[ 0.461455] iommu: Adding device 54100000.tsecb to group 18
[ 0.461636] iommu: Adding device 54480000.nvdec to group 19
[ 0.461845] iommu: Adding device 54380000.nvjpg to group 20
[ 0.462871] iommu: Adding device 546c0000.i2c to group 21
[ 0.463195] iommu: Adding device 57000000.gpu to group 22
[ 0.463272] platform 57000000.gpu: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.463312] platform 57000000.gpu: domain= (ptrval) allocates as[1]= (ptrval)
[ 0.463350] platform 57000000.gpu: domain= (ptrval) allocates as[2]= (ptrval)
[ 0.463389] platform 57000000.gpu: domain= (ptrval) allocates as[3]= (ptrval)
[ 0.464264] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.464273] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.464287] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.464293] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.464297] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.517322] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.517330] tegra-pmc: Clear bootloader IO dpd settings
[ 0.517349] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.517417] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.517717] iommu: Adding device 70012000.se to group 23
[ 0.518296] iommu: Adding device 1003000.pcie to group 24
[ 0.518346] platform 1003000.pcie: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.518775] iommu: Adding device 7000c000.i2c to group 25
[ 0.519037] iommu: Adding device 7000c400.i2c to group 26
[ 0.519290] iommu: Adding device 7000c500.i2c to group 27
[ 0.519556] iommu: Adding device 7000c700.i2c to group 28
[ 0.519823] iommu: Adding device 7000d000.i2c to group 29
[ 0.520103] iommu: Adding device 7000d100.i2c to group 30
[ 0.520359] iommu: Adding device sdhci-tegra.3 to group 31
[ 0.520411] platform sdhci-tegra.3: domain= (ptrval) allocates as[0]= (ptrval)
[ 0.521308] iommu: Adding device 700d0000.xudc to group 32
[ 0.524476] vdd-ac-bat: 5000 mV
[ 0.524836] vdd-5v0-sys: 5000 mV
[ 0.525512] vdd-5v0-hdmi: 5000 mV
[ 0.525981] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.526243] vdd-1v8-sys: 1800 mV
[ 0.526655] vdd-fan: 5000 mV
[ 0.526884] vdd-fan: supplied by vdd-5v0-sys
[ 0.527102] vdd-usb-vbus: 5000 mV
[ 0.527353] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.527691] vdd-usb-vbus2: 5000 mV
[ 0.557990] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.560341] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.562339] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.562365] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.562385] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.562773] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.570954] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.571318] SCSI subsystem initialized
[ 0.571508] libata version 3.00 loaded.
[ 0.571779] usbcore: registered new interface driver usbfs
[ 0.571829] usbcore: registered new interface driver hub
[ 0.571869] usbcore: registered new device driver usb
[ 0.575928] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.580364] vdd-core: 600 ↔ 1162 mV at 1075 mV
[ 0.581415] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.584291] vdd-ddr-1v1: 1150 mV
[ 0.589148] vdd-pre-reg-1v35: 1350 mV
[ 0.593028] vdd-1v8: 1800 mV
[ 0.597027] avdd-sys-1v2: 1200 mV
[ 0.601026] vdd-pex-1v0: 1050 mV
[ 0.601644] vddio-sdmmc-ap: 1800 ↔ 3300 mV at 3300 mV
[ 0.602164] max77620-ldo3: at 3100 mV
[ 0.605027] vdd-rtc: 850 ↔ 1100 mV at 1000 mV
[ 0.605560] max77620-ldo5: at 3100 mV
[ 0.608239] vddio-sdmmc3-ap: 1800 ↔ 3300 mV at 2800 mV
[ 0.612235] avdd-1v05-pll: 1050 mV
[ 0.616235] avdd-io-hdmi-dp: 1050 mV
[ 0.618942] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.619255] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.619550] max77620 4-003c: max77620 probe successful
[ 0.622370] media: Linux media interface: v0.10
[ 0.622435] Linux video capture interface: v2.00
[ 0.623382] pps_core: LinuxPPS API ver. 1 registered
[ 0.623386] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.623406] PTP clock support registered
[ 0.626513] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.627373] Advanced Linux Sound Architecture Driver Initialized.
[ 0.627999] Bluetooth: Core ver 2.22
[ 0.628051] NET: Registered protocol family 31
[ 0.628054] Bluetooth: HCI device and connection manager initialized
[ 0.628069] Bluetooth: HCI socket layer initialized
[ 0.628077] Bluetooth: L2CAP socket layer initialized
[ 0.628105] Bluetooth: SCO socket layer initialized
[ 0.630004] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.630022] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.630076] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.630093] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.633684] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.634817] vdd-3v3-sys: 3300 mV
[ 0.635169] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.635239] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.636327] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.636770] vdd-3v3-sd: 3300 mV
[ 0.637146] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.637933] avdd-io-edp-1v05: 1050 mV
[ 0.638289] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.638419] vdd-usb-hub-en: 5000 mV
[ 0.638759] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.639818] camchar: rtcpu character device driver loaded
[ 0.640620] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.642117] clocksource: Switched to clocksource arch_sys_counter
[ 0.683398] VFS: Disk quotas dquot_6.6.0
[ 0.683533] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.684072] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.684548] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.684569] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.684825] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.684832] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.684845] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.684877] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.684884] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.684906] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.684914] nvmap_page_pool_init: Total RAM pages: 1008798
[ 0.684917] nvmap_page_pool_init: nvmap page pool size: 126099 pages (492 MB)
[ 0.684996] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.685497] misc nvmap: created heap iram base 0x (ptrval) size (252KiB)
[ 0.686498] misc nvmap: created heap vpr base 0x (ptrval) size (409600KiB)
[ 0.694893] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.695341] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.695709] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.695979] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.696161] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.696427] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.696431] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.696900] NET: Registered protocol family 2
[ 0.697061] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.726417] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.726632] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.727191] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.727357] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.727436] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.727858] NET: Registered protocol family 1
[ 0.728635] RPC: Registered named UNIX socket transport module.
[ 0.728640] RPC: Registered udp transport module.
[ 0.728644] RPC: Registered tcp transport module.
[ 0.728648] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.728661] PCI: CLS 0 bytes, default 64
[ 0.728914] Trying to unpack rootfs image as initramfs…
[ 1.039555] Freeing initrd memory: 6992K
[ 1.049652] host1x 50000000.host1x: initialized
[ 1.051632] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.055059] audit: initializing netlink subsys (disabled)
[ 1.055132] audit: type=2000 audit(0.895:1): initialized
[ 1.055822] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.065720] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.067242] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.068061] 9p: Installing v9fs 9p2000 file system support
[ 1.071382] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.071494] io scheduler noop registered
[ 1.071820] io scheduler cfq registered (default)
[ 1.074682] gic 702f9000.agic: GIC IRQ controller registered
[ 1.077649] iommu: Adding device 702ef000.adsp to group 33
[ 1.087279] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.087461] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.088120] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7a08c0f
[ 1.088128] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.089756] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.089863] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.089960] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.090195] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.090285] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.090375] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.090466] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.090556] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.090640] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.090727] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.096910] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.098692] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.100636] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.101919] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.102312] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.103709] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.103936] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.104151] Adding domain tsec-pd to PM domain host1x-pd
[ 1.106508] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.107599] tsec 54500000.tsec: initialized
[ 1.109242] tsec 54100000.tsecb: initialized
[ 1.109986] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.113496] nvdec 54480000.nvdec: initialized
[ 1.114632] Adding domain vic03-pd to PM domain host1x-pd
[ 1.114814] Adding domain msenc-pd to PM domain host1x-pd
[ 1.114981] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.119231] falcon 54340000.vic: initialized
[ 1.120516] falcon 544c0000.nvenc: initialized
[ 1.121875] falcon 54380000.nvjpg: initialized
[ 1.126464] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=96
[ 1.126509] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.126540] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.126767] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.126828] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.126834] tegra_cec 70015000.tegra_cec: probed
[ 1.126867] display board info: id 0x0, fab 0x0
[ 1.126939] generic_infoframe_type: 0x87
[ 1.127098] tegradc tegradc.0: DT parsed successfully
[ 1.127152] tegradc tegradc.0: Display dc. (ptrval) registered with id=0
[ 1.127732] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.135173] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.135722] tegradc tegradc.0: probed
[ 1.142252] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.143730] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.143738] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.144140] kfuse 7000fc00.kfuse: initialized
[ 1.145794] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.146867] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.148546] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.148560] vdd-cpu: 708 ↔ 1322 mV at 708 mV
[ 1.149091] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.150895] vdd-gpu: applied init 1000000uV constraint
[ 1.150906] vdd-gpu: 708 ↔ 1323 mV at 997 mV
[ 1.151359] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.156103] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.156350] No Device Node present for smmu client: serial8250 !!
[ 1.156364] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.156429] iommu: Adding device serial8250 to group 35
[ 1.160195] console [ttyS0] disabled
[ 1.160315] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.160488] console [ttyS0] enabled
[ 1.161739] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.162208] serial-tegra 70006200.serial: RX in PIO mode
[ 1.162324] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.163658] [drm] Initialized
[ 1.168630] Console: switching to colour frame buffer device 240x67
[ 1.168762] tegradc tegradc.0: fb registered
[ 1.175354] brd: module loaded
[ 1.176378] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.176430] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.176976] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.176987] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.181051] loop: module loaded
[ 1.181146] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.181275] tegra_profiler: auth: init
[ 1.182844] THERMAL EST: found 2 subdevs
[ 1.182853] THERMAL EST num_resources: 0
[ 1.182869] [THERMAL EST subdev 0]
[ 1.182876] [THERMAL EST subdev 1]
[ 1.183394] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.183397] THERMAL EST: thz register success.
[ 1.183566] THERMAL EST: end of probe, return err: 0
[ 1.184941] sd: No Scsi addr parsed to reserve index
[ 1.184981] hisi_sas: driver version v1.6
[ 1.196677] tun: Universal TUN/TAP device driver, 1.6
[ 1.196687] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.198279] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.198285] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.198341] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.198344] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.198401] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.198405] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.198455] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 1.198460] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.199641] PPP generic driver version 2.4.2
[ 1.199865] PPP BSD Compression module registered
[ 1.199872] PPP Deflate Compression module registered
[ 1.199916] PPP MPPE Compression module registered
[ 1.199923] NET: Registered protocol family 24
[ 1.199998] usbcore: registered new interface driver r8152
[ 1.200045] usbcore: registered new interface driver asix
[ 1.200104] usbcore: registered new interface driver ax88179_178a
[ 1.200140] usbcore: registered new interface driver cdc_ether
[ 1.200200] usbcore: registered new interface driver net1080
[ 1.200237] usbcore: registered new interface driver cdc_subset
[ 1.200275] usbcore: registered new interface driver zaurus
[ 1.200352] usbcore: registered new interface driver cdc_ncm
[ 1.200521] VFIO - User Level meta-driver version: 0.3
[ 1.201846] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.201873] ehci-pci: EHCI PCI platform driver
[ 1.201919] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.201930] ohci-pci: OHCI PCI platform driver
[ 1.201970] ohci-platform: OHCI generic platform driver
[ 1.203597] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.203605] Extcon AUX1(HDMI) enable
[ 1.204870] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.205051] tegradc tegradc.1: No lt-data, using default setting
[ 1.205070] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.205082] tegradc tegradc.1: No hpd-gpio in DT
[ 1.205117] tegradc tegradc.1: DT parsed successfully
[ 1.205177] tegradc tegradc.1: Display dc. (ptrval) registered with id=1
[ 1.205769] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.206564] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.207038] tegra-xusb 70090000.xusb: extcon 0: (ptrval) id
[ 1.208536] usbcore: registered new interface driver uas
[ 1.208615] usbcore: registered new interface driver usb-storage
[ 1.208773] usbcore: registered new interface driver usbserial
[ 1.211357] tegra-xusb 70090000.xusb: Firmware timestamp: 2023-04-25 07:35:59 UTC, Version: 50.29 release
[ 1.211420] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.211450] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.212261] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.212309] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.212559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.212567] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.212573] usb usb1: Product: xHCI Host Controller
[ 1.212578] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.212582] usb usb1: SerialNumber: 70090000.xusb
[ 1.213288] hub 1-0:1.0: USB hub found
[ 1.213338] hub 1-0:1.0: 5 ports detected
[ 1.213640] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.213959] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.213976] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.214638] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.214778] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.214787] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.214798] usb usb2: Product: xHCI Host Controller
[ 1.214804] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[ 1.214808] usb usb2: SerialNumber: 70090000.xusb
[ 1.215601] hub 2-0:1.0: USB hub found
[ 1.215604] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.215615] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.215630] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.215643] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.215676] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.215716] hub 2-0:1.0: 4 ports detected
[ 1.216938] mousedev: PS/2 mouse device common for all mice
[ 1.217090] usbcore: registered new interface driver xpad
[ 1.217226] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.217233] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.224348] tegradc tegradc.1: probed
[ 1.224695] tegradc tegradc.1: fb registered
[ 1.227920] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.227927] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.227936] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.227950] tegradc tegradc.1: blank - powerdown
[ 1.227970] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.227975] Extcon DP: HPD disabled
[ 1.227980] hpd: hpd_switch 0
[ 1.227984] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.227992] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.227999] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.238214] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.238268] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.241847] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.326569] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.328703] rtc rtc1: alarm rtc device
[ 1.328717] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.328734] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.329095] i2c /dev entries driver
[ 1.330918] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.331324] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.331330] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.332015] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.337623] tegradc tegradc.0: blank - powerdown
[ 1.355313] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.355401] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.355465] imx219 7-0010: board setup failed
[ 1.355517] imx219: probe of 7-0010 failed with error -121
[ 1.355969] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.379244] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.379332] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.379352] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.379355] Extcon AUX1(HDMI) disable
[ 1.379390] imx219 8-0010: board setup failed
[ 1.379439] imx219: probe of 8-0010 failed with error -121
[ 1.380683] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.382711] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.382716] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.383015] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.383027] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.383033] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.383180] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.383190] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.383196] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.383340] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.383348] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.383352] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.383526] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.384119] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.384165] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.384185] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.384201] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.384209] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.385018] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.385032] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.385175] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.385196] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.385577] parse_throttle_dt_data: Num cap clks = 6
[ 1.385581] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.385588] parse_throttle_dt_data: clk=gpu type=4
[ 1.385609] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.385653] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.385674] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.385677] parse_throttle_dt_data: clk=emc type=3
[ 1.385981] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.386066] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.386194] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.386795] FAN dev name: pwm-fan
[ 1.386836] FAN:gpio request success.
[ 1.386880] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.387110] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.387233] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.387239] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.387312] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.387317] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.387321] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.387325] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.387329] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.387333] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.387337] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.387341] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.387345] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.387349] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.389617] device-mapper: uevent: version 1.0.3
[ 1.390016] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.392638] tegra210-cpufreq cpufreq: probe()…completed
[ 1.393379] sdhci: Secure Digital Host Controller Interface driver
[ 1.393380] sdhci: Copyright(c) Pierre Ossman
[ 1.393382] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.393771] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 1.403408] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.403998] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.405320] usbcore: registered new interface driver usbhid
[ 1.405321] usbhid: USB HID core driver
[ 1.406782] ashmem: initialized
[ 1.407052] tegradc tegradc.0: unblank
[ 1.407985] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.408152] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.410639] nvpmodel: initialized successfully
[ 1.411751] usbcore: registered new interface driver snd-usb-audio
[ 1.411814] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.411818] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.411835] iommu: Adding device snd-soc-dummy to group 36
[ 1.420209] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.432599] OPE platform probe
[ 1.432686] OPE platform probe successful
[ 1.432941] OPE platform probe
[ 1.433028] OPE platform probe successful
[ 1.434131] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 1.446761] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.446820] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.447845] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.456881] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 1.457013] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 1.457140] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 1.457269] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 1.457396] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 1.457525] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 1.457657] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 1.457786] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 1.457915] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 1.458041] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 1.462183] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.469943] u32 classifier
[ 1.469944] Actions configured
[ 1.470018] Initializing XFRM netlink socket
[ 1.470799] NET: Registered protocol family 10
[ 1.471509] NET: Registered protocol family 17
[ 1.471519] NET: Registered protocol family 15
[ 1.471604] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.471643] Bluetooth: RFCOMM socket layer initialized
[ 1.471652] Bluetooth: RFCOMM ver 1.11
[ 1.471656] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.471660] Bluetooth: HIDP socket layer initialized
[ 1.471677] 9pnet: Installing 9P2000 support
[ 1.471735] Key type dns_resolver registered
[ 1.472203] Registered cp15_barrier emulation handler
[ 1.472209] Registered setend emulation handler
[ 1.473328] registered taskstats version 1
[ 1.473894] Adding domain ve2-pd to PM domain host1x-pd
[ 1.474174] Adding domain ve-pd to PM domain host1x-pd
[ 1.476330] isp 54600000.isp: initialized
[ 1.477291] isp 54680000.isp: initialized
[ 1.482631] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.482634] Extcon AUX1(HDMI) enable
[ 1.486747] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.487099] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 1.489501] last reset is due to power on reset
[ 1.489504] KERNEL: PMC reset status reg: 0x0
[ 1.489598] BL: PMC reset status reg: 0x0
[ 1.489600] BL: PMIC poweroff Event Recorder: 0x40
[ 1.491104] clk_cbus_recalc_rate: no gbus parent
[ 1.491108] clk_cbus_round_rate: no gbus parent
[ 1.491109] clk_cbus_round_rate: no gbus parent
[ 1.491115] clk_cbus_recalc_rate: no gbus parent
[ 1.491211] clk_cbus_recalc_rate: no gbus parent
[ 1.491214] clk_cbus_round_rate: no gbus parent
[ 1.491216] clk_cbus_round_rate: no gbus parent
[ 1.491219] clk_cbus_recalc_rate: no gbus parent
[ 1.491291] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 1.491438] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 1.491905] tegra_dvfs: GPU-cap: registered
[ 1.491959] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.491961] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.491963] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.492743] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.492747] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.492750] usb 1-2: Product: USB2.1 Hub
[ 1.492752] usb 1-2: Manufacturer: Generic
[ 1.493525] tegra_dvfs: vdd-gpu-vts: registered
[ 1.494010] hub 1-2:1.0: USB hub found
[ 1.494331] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.494593] hub 1-2:1.0: 4 ports detected
[ 1.494971] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.495469] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.495850] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 1.498082] tegradc tegradc.0: sync windows ret = 247
[ 1.498396] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.529737] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:10 UTC (946688410)
[ 1.530786] vi 54080000.vi: vi_probe: ++
[ 1.533750] vi 54080000.vi: initialized
[ 1.536092] vi 54080000.vi: subdev nvcsi–2 bound
[ 1.536195] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.536410] mmcblk mmc0:0001: Card claimed for testing.
[ 1.538026] Disable partitions left on by BL
[ 1.538029] disb
[ 1.538073] bwmgr: missing cdev-type property
[ 1.538189] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.538196] DRAM derating cdev registered.
[ 1.539084] ALSA device list:
[ 1.539086] #0: tegra-hda at 0x70038000 irq 82
[ 1.539088] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.541598] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.546162] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.546165] Extcon HDMI: HPD enabled
[ 1.546183] tegradc tegradc.0: hdmi: plugged
[ 1.549640] Freeing unused kernel memory: 8640K
[ 1.574646] Root device found: mmcblk0p1
[ 1.576069] Found dev node: /dev/mmcblk0p1
[ 1.596560] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.598481] Rootfs mounted over mmcblk0p1
[ 1.606613] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 1.616291] Switching from initrd to actual rootfs
[ 1.634347] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 1.634352] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.634355] usb 2-1: Product: USB3.2 Hub
[ 1.634358] usb 2-1: Manufacturer: Generic
[ 1.635396] hub 2-1:1.0: USB hub found
[ 1.636157] hub 2-1:1.0: 4 ports detected
[ 1.697612] systemd[1]: System time before build time, advancing clock.
[ 1.715118] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.726549] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.737662] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.738469] systemd[1]: Detected architecture arm64.
[ 1.746130] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 1.762191] systemd[1]: Set hostname to .
[ 1.770255] usb 1-3: New USB device found, idVendor=05e3, idProduct=0751
[ 1.770260] usb 1-3: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 1.770263] usb 1-3: Product: USB Storage
[ 1.770266] usb 1-3: Manufacturer: USB Storage
[ 1.771661] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 1.772060] scsi host0: usb-storage 1-3:1.0
[ 1.790144] usb 2-1: usb_suspend_both: status 0
[ 1.790294] usb usb2: usb_suspend_both: status 0
[ 1.846176] usb 1-2.1: new low-speed USB device number 4 using tegra-xusb
[ 1.846811] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 1.846819] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 1.871620] usb 1-2.1: New USB device found, idVendor=1c4f, idProduct=0034
[ 1.871625] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.871629] usb 1-2.1: Product: Usb Mouse
[ 1.871632] usb 1-2.1: Manufacturer: SIGMACHIP
[ 1.875143] input: SIGMACHIP Usb Mouse as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:1C4F:0034.0001/input/input2
[ 1.875610] hid-generic 0003:1C4F:0034.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-70090000.xusb-2.1/input0
[ 1.946196] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.953088] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.953312] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.953401] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.955183] systemd[1]: Created slice User and Session Slice.
[ 1.955242] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.955271] systemd[1]: Reached target Swap.
[ 1.955321] systemd[1]: Reached target Mounting snaps.
[ 1.956138] systemd[1]: Created slice System Slice.
[ 1.958156] usb 1-2.3: new low-speed USB device number 5 using tegra-xusb
[ 1.979143] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 1.984361] usb 1-2.3: New USB device found, idVendor=1c4f, idProduct=0002
[ 1.984367] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.984371] usb 1-2.3: Product: USB Keyboard
[ 1.984375] usb 1-2.3: Manufacturer: SIGMACHIP
[ 1.988399] input: SIGMACHIP USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:1C4F:0002.0002/input/input3
[ 2.046827] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-70090000.xusb-2.3/input0
[ 2.050062] input: SIGMACHIP USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.1/0003:1C4F:0002.0003/input/input4
[ 2.063948] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.106531] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-70090000.xusb-2.3/input1
[ 2.142662] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.186199] usb 1-2.4: new high-speed USB device number 6 using tegra-xusb
[ 2.207186] tegra_cec 70015000.tegra_cec: Sent res: -113.
[ 2.214047] usb 1-2.4: New USB device found, idVendor=339b, idProduct=107f
[ 2.214051] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.214055] usb 1-2.4: Product: VNE-LX2
[ 2.214057] usb 1-2.4: Manufacturer: HONOR
[ 2.214060] usb 1-2.4: SerialNumber: AWVDCP3225401447
[ 2.214165] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.262208] systemd-journald[1984]: Received request to flush runtime journal from PID 1
[ 2.376262] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.378148] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.413657] usb-storage 1-2.4:1.1: USB Mass Storage device detected
[ 2.419477] scsi host1: usb-storage 1-2.4:1.1
[ 2.482506] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.482514] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.482519] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.482523] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.482528] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.482551] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.482626] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.482767] iommu: Adding device 0000:00:02.0 to group 37
[ 2.482862] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.482999] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.483026] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.483059] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[ 2.483082] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[ 2.483237] pci 0000:01:00.0: supports D1 D2
[ 2.483240] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.483402] iommu: Adding device 0000:01:00.0 to group 38
[ 2.494198] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.494234] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[ 2.494238] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.494246] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[ 2.494266] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[ 2.494284] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.494293] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.494297] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.494303] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[ 2.494583] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.494587] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.494593] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.494696] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 2.494899] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 2.494918] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 2.516058] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 2.516130] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 3c:6d:66:0a:dd:d8 from device tree
[ 2.522422] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.522440] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/ .
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/ .
[ 2.759521] using random self ethernet address
[ 2.767885] using random host ethernet address
[ 2.790954] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 1404 PQ: 0 ANSI: 6
[ 2.929772] sd 0:0:0:0: [sda] 121536512 512-byte logical blocks: (62.2 GB/58.0 GiB)
[ 2.938772] sd 0:0:0:0: [sda] Write Protect is off
[ 2.943734] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[ 2.944843] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.957169] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.967151] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 2.968806] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.971452] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.457034] scsi 1:0:0:0: CD-ROM Linux File-CD Gadget 0419 PQ: 0 ANSI: 2
[ 3.576361] Mass Storage Function, version: 2009/09/11
[ 3.576368] LUN: removable file: (no medium)
[ 3.606436] using random self ethernet address
[ 3.615010] using random host ethernet address
[ 3.642157] random: crng init done
[ 3.645590] random: 229 urandom warning(s) missed due to ratelimiting
[ 3.664267] rndis0: HOST MAC 66:5c:73:60:a3:74
[ 3.664388] rndis0: MAC 66:5c:73:60:a3:75
[ 3.670467] usb0: HOST MAC 66:5c:73:60:a3:76
[ 3.670550] usb0: MAC 66:5c:73:60:a3:77
[ 3.670581] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 3.675151] l4tbr0: port 1(rndis0) entered blocking state
[ 3.675155] l4tbr0: port 1(rndis0) entered disabled state
[ 3.676259] device rndis0 entered promiscuous mode
[ 3.682690] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 3.690845] l4tbr0: port 2(usb0) entered blocking state
[ 3.690848] l4tbr0: port 2(usb0) entered disabled state
[ 3.691375] device usb0 entered promiscuous mode
[ 3.699198] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.039584] zram: Added device: zram0
[ 4.040353] usb 1-2.1: USB disconnect, device number 4
[ 4.046819] zram: Added device: zram1
[ 4.051008] zram: Added device: zram2
[ 4.056295] zram: Added device: zram3
[ 4.091899] zram0: detected capacity change from 0 to 518508544
[ 4.124519] Adding 506352k swap on /dev/zram0. Priority:5 extents:1 across:506352k SS
[ 4.128764] zram1: detected capacity change from 0 to 518508544
[ 4.167712] Adding 506352k swap on /dev/zram1. Priority:5 extents:1 across:506352k SS
[ 4.176015] zram2: detected capacity change from 0 to 518508544
[ 4.207743] Adding 506352k swap on /dev/zram2. Priority:5 extents:1 across:506352k SS
[ 4.247290] zram3: detected capacity change from 0 to 518508544
[ 4.273929] Adding 506352k swap on /dev/zram3. Priority:5 extents:1 across:506352k SS
[ 4.302176] usb 1-2.1: new low-speed USB device number 7 using tegra-xusb
[ 4.327422] usb 1-2.1: New USB device found, idVendor=1c4f, idProduct=0034
[ 4.327428] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.327432] usb 1-2.1: Product: Usb Mouse
[ 4.327435] usb 1-2.1: Manufacturer: SIGMACHIP
[ 4.331086] input: SIGMACHIP Usb Mouse as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/0003:1C4F:0034.0004/input/input5
[ 4.331588] hid-generic 0003:1C4F:0034.0004: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-70090000.xusb-2.1/input0
[ 4.345365] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.345388] cpu-throttle-alert cooling device registered.
[ 4.347125] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.347145] gpu-throttle-alert cooling device registered.
[ 4.347338] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.347351] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.347365] hot-surface-alert cooling device registered.
[ 4.852875] Bridge firewalling registered
[ 4.894340] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.106640] Netfilter messages via NETLINK v0.30.
[ 5.110787] ctnetlink v0.93: registering with nfnetlink.
[ 5.295501] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 5.324101] tegradc tegradc.0: unblank
[ 5.324127] tegradc tegradc.1: blank - powerdown
[ 5.766703] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.849783] eth0: 0xffffff800d683000, 3c:6d:66:0a:dd:d8, IRQ 406
[ 5.965829] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.159691] fuse init (API version 7.26)
[ 13.000444] usb 1-2.4: USB disconnect, device number 6
[ 13.338130] usb 1-2.4: new high-speed USB device number 8 using tegra-xusb
[ 13.358947] usb 1-2.4: New USB device found, idVendor=0e8d, idProduct=2004
[ 13.358953] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 13.358956] usb 1-2.4: Product: VNE-LX2
[ 13.358960] usb 1-2.4: Manufacturer: HONOR
[ 13.358963] usb 1-2.4: SerialNumber: AWVDCP3225401447
[ 13.399366] rndis_host 1-2.4:1.0 usb1: register ‘rndis_host’ at usb-70090000.xusb-2.4, RNDIS device, f2:60:30:75:49:27
[ 13.400218] usbcore: registered new interface driver rndis_host
[ 13.452004] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 25.061970] tegradc tegradc.0: blank - powerdown
[ 25.115125] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 25.115141] Extcon AUX1(HDMI) disable
[ 25.135287] tegradc tegradc.1: blank - powerdown
[ 25.278754] tegradc tegradc.0: blank - powerdown
[ 25.278766] tegradc tegradc.0: unblank
[ 25.314277] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 25.314366] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 25.315387] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 25.355776] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 25.355780] Extcon AUX1(HDMI) enable
[ 25.361788] tegradc tegradc.0: unblank
[ 25.361850] tegradc tegradc.1: blank - powerdown
[ 28.453798] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 28.453809] Bluetooth: BNEP socket layer initialized
[ 28.904569] tegradc tegradc.0: unblank
[ 28.904581] tegradc tegradc.1: blank - powerdown
[ 30.825410] EXT4-fs (sda): mounted filesystem with ordered data mode. Opts: (null)
[ 31.870347] vdd-fan: disabling
[ 31.870352] vdd-usb-vbus: disabling
[ 31.870354] vdd-usb-vbus2: disabling
[ 31.870364] vddio-sdmmc-ap: disabling
[ 31.870438] vddio-sdmmc3-ap: disabling
[ 31.870497] vdd-3v3-sd: disabling
[ 31.870501] avdd-io-edp-1v05: disabling
[ 31.870504] vdd-usb-hub-en: disabling
[ 74.722926] soctherm: OC ALARM 0x00000001
finagle@ubuntu:~$
