Error nvcc fatal : Unsupported gpu architecture 'compute_87'en Jetson Nano P3450 de 4gb
nvcc fatal : Unsupported gpu architecture 'compute_87’en Jetson Nano P3450 de 4gb
Tengo error nvcc fatal : Unsupported gpu architecture 'compute_87’en Jetson Nano P3450 de 4gb
al intentar instalar OpenCV con CUDA en Python en Jetson Nano P3450 de 4gb
git clone GitHub - mdegans/nano_build_opencv: Build OpenCV on Nvidia Jetson Nano
cd nano_build_opencv
clear
jtop
gedit build_opencv.sh
git diff
./build_opencv.sh 4.8.0
jetson-nano-jose@jetson-Jose:~/nano_build_opencv$ ./build_opencv.sh 4.8.0
[ 21%] Building NVCC (Device) object modules/core/CMakeFiles/cuda_compile_1.dir/src/cuda/cuda_compile_1_generated_gpu_mat.cu.o
nvcc fatal : Unsupported gpu architecture ‘compute_87’
CMake Error at cuda_compile_1_generated_gpu_mat.cu.o.RELEASE.cmake:221 (message):
Error generating
/tmp/build_opencv/opencv/build/modules/core/CMakeFiles/cuda_compile_1.dir/src/cuda/./cuda_compile_1_generated_gpu_mat.cu.o
modules/core/CMakeFiles/opencv_core.dir/build.make:63: recipe for target ‘modules/core/CMakeFiles/cuda_compile_1.dir/src/cuda/cuda_compile_1_generated_gpu_mat.cu.o’ failed
make[2]: *** [modules/core/CMakeFiles/cuda_compile_1.dir/src/cuda/cuda_compile_1_generated_gpu_mat.cu.o] Error 1
CMakeFiles/Makefile2:2607: recipe for target ‘modules/core/CMakeFiles/opencv_core.dir/all’ failed
make[1]: *** [modules/core/CMakeFiles/opencv_core.dir/all] Error 2
Makefile:162: recipe for target ‘all’ failed
make: *** [all] Error 2
Do you wish to remove temporary build files in /tmp/build_opencv ?
(Doing so may make running tests on the build later impossible)
Y/N
CUDA 10.2 cannot compile code for GPU architecture 87.
Please remove it from the configure.
For Nano, -D CUDA_ARCH_BIN=5.3 is enough.
