ERROR - nvidia codeworks for Android 1R4 - "The manifest file is broken"
While trying to install “CodeWorks for Android 1R4”, I get the following error - “The manifest file is broken” while the NVIDIA CodeWorks for Android Component Manager is open. I am using a Dell Precision M4800 laptop with Windows 7 64bit.
I navigated to the manifest.json file located in “C:\NVIDIA\CodeWorksforAndroid” and here is the content of the json file (it looks incomplete)…
“manifest”: {
“name”:“AndroidWorks”,
“tadp”: [
“version”: “1R1”,
“url”: “http://developer.download.nvidia.com/devzone/devcenter/mobile/naw100/002/json/naw-windows-devzone.json”,
“installerMin”: “1R1”
“version”: “1R2”,
“url”: “http://developer.download.nvidia.com/devzone/devcenter/mobile/naw100/003/json/naw-windows-devzone.json”,
"install{
“manifest”: {
“tadp”: [
“version”: “1R1”,
“version”: “1R2”,
"install{
“manifest”: {
“tadp”: [
“version”: “1R1”,
“version”: “1R2”,
"install
Has anyone else ran into this issue? Is there a manifest json file somewhere that I can copy and use? Or is there so other type of solution?
Thanks in Advance
Hi User RedToast,
First sorry for the late reply. You can delete the C:\NVIDIA\CodeWorksforAndroid\manifest.json and then retry. If still not help. Please do the following steps as a walk around.
  1. Get the manifest from the http://developer.download.nvidia.com/devzone/devcenter/mobile/naw100/json/windows/manifest.json
  2. Copy the manifest.json to your install directory eg:C:\NVPACK\local.manifest
  3. Relaunch the installer and install directory choose C:\NVPACK. Then it will be work fine now.
Any more question, please let me know.
Amy
i get the same error message with 1R5…
all solutions provided above wont work…
any other ideas…?
I am getting the same error, I tried the solutions that you suggested and it still gives me the same error. I don’t know if it is relevant but in the launcher.log and the codeworks.log it says that it is unable to read the local.cfg then errno = 2
Any help would be greatly appreciated.
Hello there,
I’m installing ‘CodeWorksForAndroid 1R14’ and CodeWorksForAndroid 1R15’.
In both cases, I’m getting “The manifest file is broken” error.
I am Installing it as part of UNREAL engine on my Mac.
Please suggest me a solution for this.
Kind Regards.
Same error here even on Codeworks IR7…
Has this been resolved yet? :o]
hey running into the same issue found a reply on unreal forum suggesting need to remove the environment variable and put them back after installing but I did not get that so still stuck
