couldn't install jetpack 2.0 on tx1
I’m on a intel i7 machine with ubuntu 14.04 and the jetpack couldn’t make it through install for a tx1. If I do a ./JetPack_ver_.run I get a error of
“the manifest file is broken”
if I do a sudo ./JetPack_ver.run, the install just hangs. I’m going to see if I can flash with the l4t .tbz2 and file system directly.l
-wb
I was able to flash the x1 with the l4t os / filesystem and get the cuda-repo-l4t-r23.1-7-0-local_7.0-71_armhf.deb package installed.
sorta annoyingly, the make on the samples only builds a partial set, but the device passes the deviceQuery executable.
Is there any change you made?
Would you please provide more clear information for this issue?
Cheers
The only change I made was skip the jetpack route for installation and flash the os from a laptop with the cuda linux for tegra image. From there, on the actual tx1, post flash, I could do the install with the cuda toolkit for the L4T image.
on the make issue, Once the took kit is installed, simply going to the example folder and doing a ‘make all’ did not actually allow all of the samples to be turned into executables in a batch run.
wb
Are you going into to the samples folder at /usr/local/cuda/samples or /home/ubuntu/NVIDIA_CUDA_7.0_Samples?
The copy located in /usr/local might give permission problems unless you are building with sudo.
Were there any errors in particular from the make that you can share?
On Jetson TX1 I normally make the samples with make SMS=53.
Some of the samples are for dGPU and not meant for Tegra, these are skipped during compilation (e.g. simpleP2P, cudaDecodeGL, nvrtc).
In the past, the samples with OpenGL interop wouldn’t link out-of-the-box because of missing (GLEW, GLUT, ect), but it seems that JetPack installs these packages automatically.
JetPack will set up cross-compilation environment on host to compile CUDA samples. However, you will need install the missing packages by yourself if you want to compile CUDA samples directly on TX1 device.
my install of cuda didn’t put a copy of the samples in the /home/ubuntu but the sudo make, with the ‘SMS=53’ additions took care of the makes. -thanks dusty.
wb
Is there any solution to the initial problem “The manifest file is broken”?
Getting the same on Ubuntu 14.04 64bit.
Hi seeky15,
Can you please clean up the JetPack directory and retry? Please make sure you can access the Internet before starting JetPack.
Hello everyone,
I have the same problem with JetPack-L4T-2.0-linux-x64.run. After typing in my sudo password during the startup of the Component Manager, a error message box pops up stating “The manifest file is broken”. Clicking on ok ends the installation process. My college has the same problem with his development kit…
I tied several things with and without sudo, restarting the PC (as if we were on Windows :-)) always cleaning up the installation folder prior to the next try.
Is there any solution to this problem, besides the posibity of flashing the tx1 “by hand”.
After typing your sudo password during the startup of the Component Manager, JetPack will download <JetPack_Dir>/manifest.json file first. Can you please paste the content of this file?
Another question: is there any special setting on your machine to the Internet? Like special proxy, etc.
Hi Edward, thanks for the answer. Below is the content of the manifest file:
  "manifest": {
    "name": "JetPack L4T",
    "portfolio": [
  "manifest": {
    "portfolio": [
  "manifest": {
    "portfolio": [
I am in a company network and we do have a proxy, but what do you mean with “special”? Usually all connections to the internet work seamlessly. I am clarifying with our IT department if the file got screwed up somewhere through the servers…
In the meantime: Is it possible to obtain the file from elsewhere, download it manually and add it by hand?
I don’t know if this is a useful hint but jetpack 1.1 for the tk1 worked without problems.
Hi Phill,
The manifest.json file is downloaded from http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/json/linux-x64/manifest.json
Can you check if you are able to open it directly in browser?
The content of this file looks like the following:
  "manifest": {
    "portfolio": [
        "version": "2.0",
        "url": "http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/json/jetpack-l4t-devzone.json",
        "installerMin": "1.0"
I’ll write in another comment on how to workaround the issue.
To use manually downloaded files, please use following steps:
  1. Create <JetPack_Dir>/_installer/local.manifest file, with following content:
  "manifest": {
    "portfolio": [
        "version": "2.0",
        "url": "file:///repository.json",
  1. Download http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/json/jetpack-l4t-devzone.json and save it as <JetPack_Dir>/repository.json
  2. After Component Manager starts up, it still needs download component files to be installed. If for some unknown reason, downloaded component files are broken, you will need download them manually and put them into <JetPack_Dir>/jetpack_download/ directory. The url of these files are listed below FYI:
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/NVIDIA_Tegra_Graphics_Debugger_2.1.15301.1305_Release_External_linux-v3l_l4t.run
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/2.5.20159658-linux-x64.tar.gz
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libvisionworks-repo_1.0.25-1105_amd64_ubuntu14.04.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libvisionworks-sfm-repo_0.80.8_amd64_ubuntu14.04.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/NVIDIA_VisionWorks_References.zip
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/gl-graphics-compute-samples-linux-2.11.zip
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/common/jetpack_docs.zip
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libopencv4tegra-repo_2.4.12.3_amd64_ubuntu-14.04.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/Tegra210_Linux_R23.1.1_armhf.tbz2
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/Tegra_Linux_Sample-Root-Filesystem_R23.1.1_armhf.tbz2
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/cuda-repo-ubuntu1404-7-0-local_7.0-71_amd64.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/cuda-repo-l4t-r23.1-7-0-local_7.0-71_armhf.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/PerfKit-4.5.1-l4t.tar.gz
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/jetpack-cudnn-v4rc1-package.tgz
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libopencv4tegra-repo_2.4.12.3_armhf_l4t-r23.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libvisionworks-repo_1.0.25-287_armhf_l4t_r23.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libvisionworks-sfm-repo_0.80.8_armhf_l4t_r23.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/cuda-repo-ubuntu1404-6-5-local_6.5-50_amd64.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/Tegra124_Linux_R21.4.0_armhf.tbz2
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/Tegra_Linux_Sample-Root-Filesystem_R21.4.0_armhf.tbz2
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/cuda-repo-l4t-r21.3-6-5-local_6.5-50_armhf.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/cudnn_v2_target.tgz
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libopencv4tegra-repo_2.4.12.3_armhf_l4t-r21.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libvisionworks-repo_1.0.25-919_armhf_l4t_r21.deb
    http://developer.download.nvidia.com/devzone/devcenter/mobile/jetpack_l4t/001/linux-x64/libvisionworks-sfm-repo_0.80.8_armhf_l4t_r21.deb
Thanks for the support so far. It helped a lot.
It is no problem for me to download the files via web browser or wget, but with the Component Manager I get a download error for every single file listed in the post.
Thanks to the instructions above I was still able to install the jetpack.
I cleaned up the install folder and created the manifest and repository file as described above. With a little bash script I downloaded all the listed files to the folder <JetPack_Dir>/jetpack_download/, ran the Jetpack again and installation and flashing the device was finished without problems.
Thanks to update further information.
With more investigation, I think the broken files might be caused by optimized proxy: Range field in http header will be ignored and cached content will be used instead when downloading from the same url. Thus the multi-thread download mechanism in Component Manager doesn’t work. We’ll add support to download with single thread in future JetPack releases.
In JetPack 2.1, the command to force JetPack to use single-thread downloading is as following:
NV_DEVTOOLS_FORBID_MULTIPLE_DOWNLOAD_THREADS=1 ./JetPack-L4T-2.1-linux-x64.run
I’m trying to run JetPack L4T installer from JetPack-L4T-2.1-linux-x64.run
When Component manager window appears it has no list of packages.
All its lists and combo boxes are empty. What’s wrong with the installer?
I tried to do this with VirtualBox and real ubuntu host. The same result.
How can I make JetPack installer to download packages?
Hi vshaban,
Can you please check the previous discussions under the same topic and see if they solve your issue?
Hi Edward, thanks for your answer.
I’ve found desc how to workaround this issue.
The way is to download manually all files
and rerun Jetson installer.
For me it’s interesting how to make installer
to download and set files according to its scenario.
Thanks any way for your answer.
