1. I followed the instructions
echo "sudo docker run --runtime nvidia -it --rm --network host
-v /tmp/.X11-unix/:/tmp/.X11-unix
-v /tmp/argus_socket:/tmp/argus_socket
-v ~/my_apps:/dli/task/my_apps
–device /dev/video0 nvcr.io/nvidia/dli/dli-nano-deepstream:v2.0.0-DS6.0.1 " > ds_docker_run.sh
chmod +x ds_docker_run.sh
./ds_docker_run.sh"
and logged in to the jupyterLab server.
2. In 01-ObjDetect.ipynb, I run the cell
“# Check usage of the test1 app with the help option
!cd $PYTHON_APPS/deepstream-test1-rtsp-out
&& python3 deepstream_test1_rtsp_out.py --help”
and got the following error message:
"Traceback (most recent call last):
File “deepstream_test1_rtsp_out.py”, line 31, in
import pyds
ImportError: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
I found some similar issues on the forums but none of them worked for my case.
Solutions I tried:
I got no problem on my Nano device (Ubuntu 18.04), but it cannot go through on RTX. I saw the course uses Deepstream 6.0.1. Is it because Deepstream 6.0.1 doesn’t work on Ubuntu 20.04? I’m really confused…
