Description
I am using ngc deepstream docker container and when I try to run my pipeline i get the following error
File "main.py", line 10, in <module>
from import_libs import *
File "/root/deepstream-python/import_libs.py", line 27, in <module>
import pyds
ImportError: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
Docker container being used: DeepStream-l4t | NVIDIA NGC
I am also facing an issue while running JTOP inside the same docker.
Installed it with
sudo pip3 install jetson-stats
but whenever I try to run jtop it shows
sudo systemctl restart jetson_stats.service
I have tried restarting the container and the device.
