Hi everyone, I am using Isaac sim to simulate the following target of a robotic arm.
I want to use Script Editor to execute my code because it is more convenient for me to debug.
But I encountered some problems during use.
Because I don’t want to use the SimulationAPP, I execute my code in Script Ediotr. When I play in the UI, it keeps reporting errors.
Its error message is“Task name should be unique in the world”
I didn’t import the Class, but instead put the entire code into Script Editor for execution
I hope to receive some help, thank you very much.
My code:
from omni.isaac.manipulators import SingleManipulator
from omni.isaac.manipulators.grippers import ParallelGripper
from omni.isaac.core.utils.stage import add_reference_to_stage
import omni.isaac.core.tasks as tasks
from typing import Optional
import numpy as np
import asyncio
class FollowTarget(tasks.FollowTarget):
def __init__(
self,
name: str = "denso_follow_target",
target_prim_path: Optional[str] = None,
target_name: Optional[str] = None,
target_position: Optional[np.ndarray] = None,
target_orientation: Optional[np.ndarray] = None,
offset: Optional[np.ndarray] = None,
) -> None:
tasks.FollowTarget.__init__(
self,
name=name,
target_prim_path=target_prim_path,
target_name=target_name,
target_position=target_position,
target_orientation=target_orientation,
offset=offset,
return
def set_robot(self) -> SingleManipulator:
#TODO: change this to the robot usd file.
asset_path = "C:/Users/Administrator/Desktop/testarm/xin/3/Cobotta_Pro_900_Assets/Cobotta_Pro_900_Assets/cobotta_pro_900.usd"
add_reference_to_stage(usd_path=asset_path, prim_path="/World/cobotta")
gripper = ParallelGripper(
end_effector_prim_path="/World/cobotta/onrobot_rg6_base_link",
joint_prim_names=["finger_joint", "right_outer_knuckle_joint"],
joint_opened_positions=np.array([0, 0]),
joint_closed_positions=np.array([0.628, -0.628]),
action_deltas=np.array([-0.628, 0.628]))
manipulator = SingleManipulator(prim_path="/World/cobotta",
name="cobotta_robot",
end_effector_prim_name="onrobot_rg6_base_link",
gripper=gripper)
joints_default_positions = np.zeros(12)
joints_default_positions[7] = 0.628
joints_default_positions[8] = 0.628
manipulator.set_joints_default_state(positions=joints_default_positions)
return manipulator
from omni.isaac.core import World
my_world = World(stage_units_in_meters=1.0)
my_task = FollowTarget(name="denso_follow_target", target_position=np.array([0.5, 0, 0.5]))
my_world.add_task(my_task)
my_world.reset()
task_params = my_world.get_task("denso_follow_target").get_params()
target_name = task_params["target_name"]["value"]
denso_name = task_params["robot_name"]["value"]
my_denso = my_world.scene.get_object(denso_name)
articulation_controller = my_denso.get_articulation_controller()
flag=True
while flag==True:
my_world.step(render=True)
if my_world.is_playing():
if my_world.current_time_step_index == 0:
my_world.reset()
observations = my_world.get_observations()
print(observations)
