Isaac sim How to use external data to control the movement of the robot arm
code:
from omni.isaac.examples.base_sample import BaseSample
from omni.isaac.franka import Franka
from omni.isaac.core.objects import DynamicCuboid
from omni.isaac.franka.controllers import PickPlaceController
from omni.isaac.core.tasks import BaseTask
import numpy as np
class FrankaPlaying(BaseTask):
def __init__(self, name):
    super().__init__(name=name, offset=None)
    self.current_line = 0
    self._goal_position = np.array([-0.3, -0.3, 0.0515 / 2.0])
    self._task_achieved = False
    return
# 场景设置
def set_up_scene(self, scene):
    super().set_up_scene(scene)
    scene.add_default_ground_plane()
    self._cube = scene.add(DynamicCuboid(prim_path="/World/random_cube",
                                        name="fancy_cube",
                                        position=np.array([0.3, 0.3, 0.3]),
                                        scale=np.array([0.0515, 0.0515, 0.0515]),
                                        color=np.array([0, 0, 1.0])))
    self._franka = scene.add(Franka(prim_path="/World/Fancy_Franka",
                                    name="fancy_franka"))
    return
file_object = None
# 定义全局变量,用于保存文件对象和文件路径
def next_line():
    global file_object
    if FrankaPlaying.file_object is None:
        # 第一次调用时打开文件
        FrankaPlaying.file_object = open('C:\data\output.txt', 'r')
    # 读取文件的下一行
    line = FrankaPlaying.file_object.readline().strip()
    line = np.array([line])
    if not line:
        #如果到达文件末尾,重新打开文件并返回第一行
        FrankaPlaying.file_object.close()
    return line
# 获取场景信息
def get_observations(self):
    cube_position, _ = self._cube.get_world_pose()
    current_joint_positions = FrankaPlaying.next_line()
    print("关节的位置为: ", current_joint_positions)
    observations = {
        self._franka.name: {
            "joint_positions": current_joint_positions,
        self._cube.name: {
            "position": cube_position,
            "goal_position": self._goal_position
    return observations
# 每一步的操作
def pre_step(self, control_index, simulation_time):
    if not self._task_achieved and np.mean(np.abs(self._goal_position - cube_position)) < 0.02:
        #改变方块颜色
        self._cube.get_applied_visual_material().set_color(color=np.array([0, 1.0, 0]))
        self._task_achieved = True
    return
#重置
def post_reset(self):
    self._franka.gripper.set_joint_positions(self._franka.gripper.joint_opened_positions)
    self._cube.get_applied_visual_material().set_color(color=np.array([0, 0, 1.0]))
    return
class HelloWorld(BaseSample):
def init(self) → None:
super().init()
return
def setup_scene(self):
    world = self.get_world()
    # 添加任务
    world.add_task(FrankaPlaying(name="my_first_task"))
    return
# 加载后
async def setup_post_load(self):
    self._world = self.get_world()
    self._franka = self._world.scene.get_object("fancy_franka")
    # 创建控制器
    self._controller = PickPlaceController(
        name="pick_place_controller",
        gripper=self._franka.gripper,
        robot_articulation=self._franka,
    # 添加物理回调
    self._world.add_physics_callback("sim_step", callback_fn=self.physics_step)
    # 运行
    await self._world.play_async()
    return
# 重置
async def setup_post_reset(self):
    self._controller.reset()
    # 重置7
    return
# 物理步
def physics_step(self, step_size):
    # 获取当前观察
    current_observations = self._world.get_observations()
    # 获取动作
    actions = self._controller.forward(
        picking_position=current_observations["fancy_cube"]["position"],
        placing_position=current_observations["fancy_cube"]["goal_position"],
        current_joint_positions=current_observations["fancy_franka"]["joint_positions"],
    #  执行动作
    self._franka.apply_action(actions)
    if self._controller.is_done():
        self._world.pause()
    return
Hi @hiteam_yangyan - Following documents would be useful to you:
Let us know if you have any follow-up questions.
