I am experiencing the same error pattern. Does someone have any insights or some way forward?
Mario
C:\Users\mabou
“\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\bin\win64\Debug\deviceQuery.exe”
\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\bin\win64\Debug\deviceQuery.exe Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: “GeForce GTX 965M”
CUDA Driver Version / Runtime Version 9.0 / 9.0
CUDA Capability Major/Minor version number: 5.2
Total amount of global memory: 2048 MBytes (2147483648 bytes)
( 8) Multiprocessors, (128) CUDA Cores/MP: 1024 CUDA Cores
GPU Max Clock rate: 1150 MHz (1.15 GHz)
Memory Clock rate: 2505 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 1048576 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 1
Result = PASS
C:\Users\mabou
“\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\bin\win64\Debug\bandwidthTest.exe”
[CUDA Bandwidth Test] - Starting…
Running on…
Device 0: GeForce GTX 965M
Quick Mode
CUDA error at C:/ProgramData/NVIDIA Corporation/CUDA Samples/v9.0/1_Utilities/bandwidthTest/bandwidthTest.cu:837 code=6(cudaErrorLaunchTimeout) “cudaFree(d_idata)”
C:\Users\mabou
“\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\bin\win64\Debug\bandwidthTest.exe” -dtod
Running on…
Quick Mode
Device to Device Bandwidth, 1 Device(s)
PINNED Memory Transfers
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 66853.8
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
C:\Users\mabou
“\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\bin\win64\Debug\bandwidthTest.exe” -dtoh
Running on…
Quick Mode
Device to Host Bandwidth, 1 Device(s)
33554432 1610.4
Result = PASS
C:\Users\mabou
“\ProgramData\NVIDIA Corporation\CUDA Samples\v9.0\bin\win64\Debug\bandwidthTest.exe” -htod
Running on…
Quick Mode
