• Hardware Platform (Jetson / GPU): Jetson AGX Xavier
• DeepStream Version: 5.0
• JetPack Version (valid for Jetson only): 4.4
• TensorRT Version: 7.1.3
• Issue Type( questions, new requirements, bugs): bugs
• How to reproduce the issue ?
I followed the README instructions in /opt/nvidia/deepstream/deepstream/sources/libs/kafka_protocol_adaptor and installed all dependencies (librdkafka, glib 2.0, jansson), them simply use make command to build deepstream-test4-app.
- command line:
./deepstream-test4-app -i ../../../../samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so --conn-str="<IP address>;9092" --topic=quickstart-events --schema=0 --no-display --cfg-file=cfg_kafka.txt
Where <IP address> is the IP address of another computer running a Kafka server, created by follow the instructions from Apache Kafka
The topic is created with: bin/kafka-topics.sh --create --topic quickstart-events --bootstrap-server <IP address>:9092
- cfg_kafka.txt:
[message-broker]
partition-key = sensor.id
#share-connection = 1
- Errors:
%3|1607384478.520|FAIL|rdkafka#producer-1| [thrd:kt-ThinkStation-P510:9092/0]: kt-ThinkStation-P510:9092/0: Failed to resolve ‘kt-ThinkStation-P510:9092’: Name or service not known
%3|1607384478.520|ERROR|rdkafka#producer-1| [thrd:kt-ThinkStation-P510:9092/0]: kt-ThinkStation-P510:9092/0: Failed to resolve ‘kt-ThinkStation-P510:9092’: Name or service not known
I simply want to send messages to another computer that run a Kafka server then view them in the terminal. Please advice on how to fix the above error.
