Hi @diegogarzon, that container is for JetPack 4.x and the course for the original Jetson Nano. You could copy the notebooks out of it and run them in the l4t-ml container instead (which is available for JetPack 5 and is pretty close to the DLI container - I think you may need to install jetcam). The Hello AI World tutorial is also on JetPack 5.
I will check with the DLI team with this and see if it’s on their radar to upgrade/support the course for Orin Nano. I suspect that the changes to the documentation and guides (which are based around the original Nano) are more significant than rebuilding the container for JetPack 5. Thanks for expressing your interest in this, and hope that for the time being that you’ll find our other tutorials to help get you started - good luck!
