Getting Started with AI on Jetson Nano course on jetson orin nano developer kit
I am following the steps in the Getting Started with AI on Jetson Nano course, and i am using jetson orin nano developer kit 8 GB, after installing the docker container, i encountered some issues, and then i noticed that the container is compatible at the latest with JetPack 4.6.1, and i use JetPack 5.1.2 for the orin, since JetPack 4.6.1 doesn’t support jetson orin, is there any workaround to get the docker container work on the jetson orin nano ?
Best Regards,
Hi @musaab_taha, as you’ve found, that course and it’s container are only supported on Jetson Nano, however you can attempt to run the notebooks from it in another container like nvcr.io/nvidia/l4t-ml:r35.2.1-py3. And see this post to install jetcam in it:
Hi dusty-nv, thank you a lot for your help, it worked for me.
Best Regards,
