ImportError: /lib/aarch64-linux-gnu/libm.so.6: version `GLIBC_2.29' not found (required by /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0)
Jetson Orin
• DeepStream Version
6.2
5.0.2
• TensorRT Version
8.4.1-1+cuda11.4
I am having the exact same issue as in:
I am following the course: Building Video AI Applications at the Edge on Jetson Nano and when running the cell
# Check usage of the test1 app with the help option
!cd $PYTHON_APPS/deepstream-test1-rtsp-out \
    && python3 deepstream_test1_rtsp_out.py --help
I get the following error:
  File "deepstream_test1_rtsp_out.py", line 31, in <module>
    import pyds
I used the following command to start the docker:
sudo docker run --runtime nvidia -it --rm --network host \
     -v /tmp/.X11-unix/:/tmp/.X11-unix \
     -v /tmp/argus_socket:/tmp/argus_socket \
     -v ~/my_apps:/dli/task/my_apps \
     --device /dev/video0 \
     nvcr.io/nvidia/dli/dli-nano-deepstream:v2.0.0-DS6.0.1
Edit:
I tried running the sample code locally in my jetson and I get the following error:
  File "deepstream_test1_rtsp_out.py", line 26, in <module>
    gi.require_version('GstRtspServer', '1.0')
  File "/usr/lib/python3/dist-packages/gi/__init__.py", line 129, in require_version
    raise ValueError('Namespace %s not available' % namespace)
ValueError: Namespace GstRtspServer not available
Edit2:
Running:
sudo apt install gir1.2-gst-rtsp-server-1.0
Fixed the error above
  1. can you run deepstream_test1_rtsp_out.py directly on device?
  2. did you succeed to build pdys bindings according to deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub?
  1. I can run deepstream_test1_rtsp_out.py on the device successfully.
  2. Do I need to build pdys bindings if I’m using the docker container?
yes, you need to build pdys bindings
