Error starting Isaac sim from docker
Hi all,
I have some problems while running Isaac Sim via docker and Websocket. I followed all the tutorials, and I managed to access the broadcast of Isaac’s GUI. However, while the GUI opens, in my terminal, I see this error:
[Error] [carb.crashreporter-breakpad.plugin] failed to upload minidump: file: '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/2e1b0127-c038-4c91-d1a8d49d-cbb64873.dmp.zip', code: 0, error: 'libcurl.so: cannot open shared object file: No such file or directory', response:
[Error] [carb.crashreporter-breakpad.plugin]      {status = InitFailed (3)}
Does anyone know what does this error mean? How can I solve it?
Best,
Francesco
Hi. Please share your full log. Some questions:
  • Which browser are you using?
  • How do you run the container?
  • Is your container and browser on the same machine or the same local network?
  • Does WebRTC or Omniverse Streaming Client work?
Thank you for the quick answer! Here I provide what you asked:
Complete log file
[Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/2e1b0127-c038-4c91-d1a8d49d-cbb64873.dmp.zip' svr:'https://services.nvidia.com/submit'
[Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
[Warning] [carb.crashreporter-breakpad.plugin]   CarbSdkVersion = '129.11+129.tc565.0f371ae5'
[Warning] [carb.crashreporter-breakpad.plugin]   DumpId = '2e1b0127-c038-4c91-d1a8d49d-cbb64873'
[Warning] [carb.crashreporter-breakpad.plugin]   ProductName = 'OmniverseKit'
[Warning] [carb.crashreporter-breakpad.plugin]   RetryCount = '2'
[Warning] [carb.crashreporter-breakpad.plugin]   SentOnLaterRun = 'true'
[Warning] [carb.crashreporter-breakpad.plugin]   StartupTime = '1685604599'
[Warning] [carb.crashreporter-breakpad.plugin]   UploadSuccessful = '0'
[Warning] [carb.crashreporter-breakpad.plugin]   UptimeSeconds = '8'
[Warning] [carb.crashreporter-breakpad.plugin]   Version = '104.2+release.295.529af2e4.tc'
[Warning] [carb.crashreporter-breakpad.plugin]   appName = 'Isaac-Sim'
[Warning] [carb.crashreporter-breakpad.plugin]   appState = 'startup'
[Warning] [carb.crashreporter-breakpad.plugin]   appVersion = '2022.2.1'
[Warning] [carb.crashreporter-breakpad.plugin]   buildBranch = 'release'
[Warning] [carb.crashreporter-breakpad.plugin]   buildCi = 'tc'
[Warning] [carb.crashreporter-breakpad.plugin]   buildHash = '529af2e4'
[Warning] [carb.crashreporter-breakpad.plugin]   buildId = '14001715'
[Warning] [carb.crashreporter-breakpad.plugin]   buildMajor = '104'
[Warning] [carb.crashreporter-breakpad.plugin]   buildMinor = '2'
[Warning] [carb.crashreporter-breakpad.plugin]   buildMr = '0'
[Warning] [carb.crashreporter-breakpad.plugin]   buildNumber = '295'
[Warning] [carb.crashreporter-breakpad.plugin]   buildPatch = '0'
[Warning] [carb.crashreporter-breakpad.plugin]   buildVersion = '104.2.0'
[Warning] [carb.crashreporter-breakpad.plugin]   environmentName = 'default'
[Warning] [carb.crashreporter-breakpad.plugin]   experience = 'Isaac Sim'
[Warning] [carb.crashreporter-breakpad.plugin]   kitRendererDriverVersion = '525.105'
[Warning] [carb.crashreporter-breakpad.plugin]   lastCommand = 'URDFCreateImportConfig'
[Warning] [carb.crashreporter-breakpad.plugin]   lastCommands = 'MJCFCreateImportConfig,URDFCreateImportConfig'
[Warning] [carb.crashreporter-breakpad.plugin]   memoryStats = '(avail/total) RAM: 83.3344/125.622GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
[Warning] [carb.crashreporter-breakpad.plugin]   portableMode = '0'
[Warning] [carb.crashreporter-breakpad.plugin]   systemInfo = '
| Driver Version: 525.105.17    | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA RTX A6000                 | Yes: 0 |     | 49386   MB | 10de      | 0          |
|     |                                  |        |     |            | 2230      | f73de1ea.. |
| OS: Linux sbtc-P620, Version: 5.14.0-1059-oem
| Processor: AMD Ryzen Threadripper PRO 5975WX 32-Cores      | Cores: Unknown | Logical: 64
| Total Memory (MB): 128637 | Free Memory: 87661
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[Warning] [carb.crashreporter-breakpad.plugin]   telemetrySessionId = '6283411421514960473'
[Warning] [carb.crashreporter-breakpad.plugin]   userId = 'default'
[Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
[Warning] [carb.crashreporter-breakpad.plugin]   upload_file_minidump = '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/2e1b0127-c038-4c91-d1a8d49d-cbb64873.dmp.zip'
Loading user config located at: '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/user.config.json'
[Info] [carb] Logging to file: /root/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20230602_072532.log
2023-06-02 07:25:32 [98ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.lidar] Extensions config 'extension.toml' doesn't exist '/isaac-sim/exts/omni.sensors.nv.lidar' or '/isaac-sim/exts/omni.sensors.nv.lidar/config'
2023-06-02 07:25:32 [98ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.radar] Extensions config 'extension.toml' doesn't exist '/isaac-sim/exts/omni.sensors.nv.radar' or '/isaac-sim/exts/omni.sensors.nv.radar/config'
[0.420s] [ext: omni.stats-0.0.0] startup
[0.455s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.468s] [ext: omni.assets.plugins-0.0.0] startup
[0.471s] [ext: omni.gpu_foundation-0.0.0] startup
[0.485s] [ext: carb.windowing.plugins-1.0.0] startup
2023-06-02 07:25:32 [449ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-06-02 07:25:32 [449ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[0.486s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 525.60.11     | Graphics API: Vulkan
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2230      | f73de1ea.. |
| Total Memory (MB): 128637 | Free Memory: 101056
2023-06-02 07:25:33 [1,192ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled. Found 64 items in /sys/kernel/iommu_groups/.
2023-06-02 07:25:33 [1,192ms] [Warning] [gpu.foundation.plugin] On Linux only, CUDA and the display driver does not support IOMMU-enabled bare-metal PCIe peer to peer memory copy.
However, CUDA and the display driver does support IOMMU via VM pass through. As a consequence, users on Linux,
when running on a native bare metal system, should disable the IOMMU. The IOMMU should be enabled and the VFIO driver
be used as a PCIe pass through for virtual machines.
2023-06-02 07:25:33 [1,192ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2023-06-02 07:25:33 [1,192ms] [Warning] [gpu.foundation.plugin] !!!!! Local system validation failed! Incorrect configuration detected.
2023-06-02 07:25:33 [1,193ms] [Warning] [gpu.foundation.plugin]       Summary below. Details above.
2023-06-02 07:25:33 [1,193ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2023-06-02 07:25:33 [1,193ms] [Warning] [gpu.foundation.plugin]  - ECC:                         OK
2023-06-02 07:25:33 [1,193ms] [Warning] [gpu.foundation.plugin]  - IOMMU:                       FAILED
[1.714s] [ext: omni.kit.pipapi-0.0.0] startup
[1.733s] [ext: omni.usd.config-1.0.0] startup
[1.739s] [ext: omni.usd.libs-1.0.0] startup
[1.887s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.910s] [ext: omni.kit.async_engine-0.0.0] startup
[1.912s] [ext: omni.kit.loop-default-0.1.1] startup
[1.912s] [ext: omni.kit.test-0.0.0] startup
[2.121s] [ext: omni.usd.schema.semantics-0.0.0] startup
[2.169s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.180s] [ext: omni.client-0.1.1] startup
[2.192s] [ext: omni.iray.libs-0.0.0] startup
[2.200s] [ext: omni.volume-0.1.0] startup
[2.203s] [ext: omni.usd.core-1.0.4] startup
[2.207s] [ext: omni.mdl.neuraylib-0.1.0] startup
[2.213s] [ext: omni.hydra.rtx-0.1.0] startup
[2.224s] [ext: omni.hydra.iray-0.1.0] startup
[2.226s] [ext: omni.isaac.core_archive-2.0.1] startup
[2.521s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[2.526s] [ext: omni.isaac.ml_archive-1.1.0] startup
[2.630s] [ext: omni.services.pip_archive-0.4.2] startup
[2.634s] [ext: omni.appwindow-1.0.1] startup
2023-06-02 07:25:34 [2,599ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-06-02 07:25:34 [2,599ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[2.637s] [ext: omni.kit.renderer.core-0.0.0] startup
2023-06-02 07:25:34 [2,602ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-06-02 07:25:34 [2,602ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[2.645s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.648s] [ext: omni.kit.renderer.imgui-0.0.0] startup
2023-06-02 07:25:34 [2,615ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-06-02 07:25:34 [2,615ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[2.724s] [ext: omni.ui-2.14.4] startup
[2.737s] [ext: carb.audio-0.1.0] startup
[2.761s] [ext: omni.uiaudio-1.0.0] startup
[2.763s] [ext: omni.kit.mainwindow-1.0.0] startup
[2.766s] [ext: omni.kit.uiapp-0.0.0] startup
[2.766s] [ext: omni.usd.schema.physics-1.0.0] startup
[2.778s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[2.780s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[2.791s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.822s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[2.832s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[2.842s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.931s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[2.942s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[2.944s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[2.951s] [ext: omni.kit.actions.core-1.0.0] startup
[2.955s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.956s] [ext: omni.kit.commands-1.4.5] startup
[2.964s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[2.978s] [ext: omni.timeline-1.0.5] startup
[2.980s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[3.023s] [ext: omni.usd-1.6.30] startup
[3.101s] [ext: omni.usd.fileformat.e57-0.1.11] startup
[3.102s] [ext: omni.usd.schema.flow-104.1.6] startup
[3.103s] [ext: omni.usd.schema.sequence-2.2.1] startup
[3.114s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[3.125s] [ext: omni.usd.schema.isaac-1.1.0] startup
[3.145s] [ext: omni.usd.fileformat.sbsar-0.9.11] startup
[3.192s] [ext: omni.kit.asset_converter-1.3.4] startup
[3.247s] [ext: omni.usd.schema.destruction-0.4.0] startup
[3.257s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[3.263s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[3.266s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[3.272s] [ext: omni.hydra.engine.stats-1.0.0] startup
[3.279s] [ext: omni.kit.usd.layers-2.0.11] startup
[3.302s] [ext: omni.kit.menu.utils-1.4.7] startup
[3.322s] [ext: omni.ui_query-1.1.1] startup
[3.324s] [ext: omni.kvdb-0.0.0] startup
[3.326s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[3.345s] [ext: omni.kit.ui_test-1.2.9] startup
[3.351s] [ext: omni.kit.notification_manager-1.0.5] startup
[3.362s] [ext: omni.activity.core-1.0.1] startup
[3.367s] [ext: omni.kit.stage_templates-1.1.13] startup
[3.373s] [ext: omni.kit.widget.path_field-2.0.4] startup
[3.376s] [ext: omni.kit.widget.versioning-1.3.8] startup
[3.384s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[3.431s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[3.434s] [ext: omni.kit.search_core-1.0.2] startup
[3.436s] [ext: omni.kit.window.drop_support-1.0.1] startup
[3.437s] [ext: omni.kit.window.filepicker-2.7.15] startup
UsdE57FileFormat
[3.563s] [ext: omni.mdl-0.1.0] startup
[3.677s] [ext: omni.kit.window.file_importer-1.0.10] startup
[3.680s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[3.682s] [ext: omni.kit.material.library-1.3.21] startup
[3.697s] [ext: omni.kit.clipboard-1.0.0] startup
[3.698s] [ext: omni.kit.menu.create-1.0.8] startup
[3.702s] [ext: omni.hydra.pxr-1.1.2] startup
[3.705s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[3.708s] [ext: omni.kit.context_menu-1.5.12] startup
[3.721s] [ext: omni.kit.hydra_texture-1.0.11] startup
[3.726s] [ext: omni.kit.widget.stage-2.7.24] startup
[3.747s] [ext: omni.kit.window.file-1.3.32] startup
[3.761s] [ext: omni.kit.window.property-1.8.2] startup
[3.767s] [ext: omni.kit.window.content_browser-2.6.8] startup
[3.833s] [ext: omni.kit.widget.viewport-104.1.16] startup
[3.848s] [ext: omni.ui.scene-1.5.18] startup
[3.855s] [ext: omni.kit.viewport.registry-104.0.2] startup
[3.857s] [ext: omni.kit.property.usd-3.18.17] startup
[3.906s] [ext: omni.physics.tensors-0.1.0] startup
[3.923s] [ext: omni.kit.viewport.window-104.1.23] startup
[3.981s] [ext: omni.localcache-0.0.0] startup
[3.984s] [ext: omni.ramp-104.1.3] startup
[3.998s] [ext: omni.usdphysics-104.2.4-5.1] startup
[4.000s] [ext: omni.kit.viewport.utility-1.0.14] startup
[4.004s] [ext: omni.kit.widget.prompt-1.0.5] startup
[4.007s] [ext: omni.physx-104.2.4-5.1] startup
[4.055s] [ext: omni.kit.numpy.common-0.1.0] startup
[4.058s] [ext: omni.inspect-1.0.1] startup
[4.061s] [ext: omni.kit.usd_undo-0.1.2] startup
[4.063s] [ext: omni.graph.tools-1.17.2] startup
[4.129s] [ext: omni.graph.core-2.65.4] startup
[4.132s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[4.262s] [ext: omni.debugdraw-0.1.1] startup
[4.267s] [ext: omni.graph-1.50.2] startup
[4.373s] [ext: omni.kit.window.extensions-1.1.1] startup
[4.401s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[4.403s] [ext: omni.kit.widget.settings-1.0.1] startup
[4.410s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[4.415s] [ext: omni.kit.window.preferences-1.3.8] startup
[4.474s] [ext: omni.scene.visualization.core-104.4.0] startup
[4.569s] [ext: omni.graph.ui-1.24.2] startup
[4.695s] [ext: omni.physx.tensors-0.1.0] startup
[4.709s] [ext: omni.genproc.core-104.5.14] startup
[4.745s] [ext: omni.isaac.version-1.0.0] startup
[4.747s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[4.771s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[4.785s] [ext: omni.isaac.core-1.46.3] startup
[6.328s] [ext: omni.graph.action-1.31.1] startup
[6.342s] [ext: omni.graph.io-1.2.5] startup
[6.350s] [ext: omni.isaac.ui-0.8.0] startup
[6.368s] [ext: omni.genproc.ui-104.1.6] startup
[6.378s] [ext: usdrt.scenegraph-4.3.2] startup
[6.398s] [ext: omni.genproc.bundle-104.0.1] startup
[6.398s] [ext: omni.graph.examples.cpp-1.4.2] startup
[6.402s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[6.405s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[6.409s] [ext: omni.command.usd-1.0.2] startup
[6.415s] [ext: omni.kit.browser.core-2.2.2] startup
[6.431s] [ext: omni.kit.widget.spinner-1.0.4] startup
[6.433s] [ext: omni.kit.window.cursor-1.1.1] startup
[6.435s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[6.448s] [ext: omni.graph.nodes-1.48.3] startup
[6.468s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
[6.518s] [ext: omni.kit.browser.sample-1.2.5] startup
[6.522s] [ext: omni.graph.scriptnode-0.10.0] startup
[6.528s] [ext: omni.syntheticdata-0.2.4] startup
2023-06-02 07:25:38 [6,531ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[6.576s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
   CUDA Toolkit: 11.5, Driver: 12.0
   Devices:
     "cpu"    | x86_64
     "cuda:0" | NVIDIA RTX A6000 (sm_86)
   Kernel cache: /root/.cache/warp/0.6.3
WARNING: Attribute 'inputs:mass' description should not be empty
WARNING: Attribute 'inputs:radius' description should not be empty
WARNING: Attribute 'inputs:k_contact_elastic' description should not be empty
WARNING: Attribute 'inputs:k_contact_damp' description should not be empty
WARNING: Attribute 'inputs:k_contact_friction' description should not be empty
WARNING: Attribute 'inputs:k_contact_mu' description should not be empty
WARNING: Attribute 'inputs:k_contact_cohesion' description should not be empty
WARNING: Attribute 'inputs:k_contact_adhesion' description should not be empty
WARNING: Attribute 'inputs:num_substeps' description should not be empty
WARNING: Attribute 'inputs:gravity' description should not be empty
WARNING: Attribute 'inputs:ground' description should not be empty
WARNING: Attribute 'inputs:ground_plane' description should not be empty
WARNING: Attribute 'inputs:asynchronous' description should not be empty
WARNING: Attribute 'inputs:execIn' description should not be empty
WARNING: Attribute 'inputs:sdf_min' description should not be empty
WARNING: Attribute 'inputs:sdf_max' description should not be empty
WARNING: Attribute 'inputs:spacing' description should not be empty
WARNING: Attribute 'inputs:spacing_jitter' description should not be empty
WARNING: Attribute 'inputs:velocity' description should not be empty
WARNING: Attribute 'inputs:max_points' description should not be empty
WARNING: Attribute 'inputs:fps' description should not be empty
WARNING: Attribute 'inputs:start' description should not be empty
WARNING: Attribute 'inputs:end' description should not be empty
WARNING: Attribute 'outputs:time' description should not be empty
WARNING: Node description should not be empty
WARNING: Attribute 'inputs:resolution' description should not be empty
WARNING: Attribute 'inputs:speed' description should not be empty
WARNING: Attribute 'inputs:damp' description should not be empty
WARNING: Attribute 'inputs:grid' description should not be empty
WARNING: Attribute 'inputs:collider_0' description should not be empty
WARNING: Attribute 'inputs:collider_1' description should not be empty
WARNING: Attribute 'inputs:collider_2' description should not be empty
WARNING: Attribute 'inputs:collider_3' description should not be empty
WARNING: Attribute 'inputs:buoyancy_enabled' description should not be empty
WARNING: Attribute 'inputs:density_0' description should not be empty
WARNING: Attribute 'inputs:density_1' description should not be empty
WARNING: Attribute 'inputs:density_2' description should not be empty
WARNING: Attribute 'inputs:density_3' description should not be empty
WARNING: Attribute 'inputs:displace' description should not be empty
WARNING: Attribute 'inputs:buoyancy' description should not be empty
WARNING: Attribute 'inputs:buoyancy_damp' description should not be empty
WARNING: Attribute 'inputs:delay' description should not be empty
WARNING: Attribute 'outputs:vertices' description should not be empty
WARNING: Attribute 'outputs:face_indices' description should not be empty
WARNING: Attribute 'outputs:face_counts' description should not be empty
WARNING: Attribute 'inputs:collider_offset' description should not be empty
WARNING: Attribute 'inputs:density' description should not be empty
WARNING: Attribute 'inputs:k_tri_elastic' description should not be empty
WARNING: Attribute 'inputs:k_tri_area' description should not be empty
WARNING: Attribute 'inputs:k_tri_damp' description should not be empty
WARNING: Attribute 'inputs:k_edge_bend' description should not be empty
WARNING: Attribute 'inputs:k_edge_damp' description should not be empty
[6.970s] [ext: omni.anim.curve-104.16.6] startup
[7.007s] [ext: omni.isaac.debug_draw-0.2.3] startup
[7.014s] [ext: omni.replicator.core-1.7.8] startup
2023-06-02 07:25:39 [7,272ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[7.467s] [ext: omni.kit.widget.timeline-104.0.3] startup
[7.479s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[7.482s] [ext: omni.isaac.range_sensor-0.8.1] startup
[7.553s] [ext: omni.isaac.core_nodes-0.23.2] startup
[7.588s] [ext: omni.anim.curve_editor-104.12.7] startup
[7.635s] [ext: omni.isaac.sensor-5.6.3] startup
2023-06-02 07:25:39 [7,599ms] [Warning] [omni.ext.plugin] [ext: omni.isaac.sensor-5.6.3] Native plugin search dir contains several files: /isaac-sim/exts/omni.isaac.sensor/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[7.696s] [ext: omni.isaac.lula-1.2.1] startup
[7.707s] [ext: omni.isaac.motion_planning-0.2.2] startup
[7.717s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[7.758s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[7.768s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[7.802s] [ext: omni.isaac.motion_generation-4.5.6] startup
[7.830s] [ext: omni.isaac.manipulators-1.1.0] startup
[7.834s] [ext: omni.kit.widget.layers-1.6.11] startup
[7.876s] [ext: omni.isaac.franka-0.4.0] startup
[7.878s] [ext: omni.isaac.utils-0.2.4] startup
[7.885s] [ext: omni.isaac.cortex-0.3.2] startup
[7.885s] [ext: omni.isaac.demos-0.3.3] startup
[7.928s] [ext: omni.isaac.dofbot-0.3.0] startup
[7.931s] [ext: omni.isaac.quadruped-1.3.0] startup
[8.677s] [ext: omni.kit.property.layer-1.1.4] startup
[8.683s] [ext: omni.isaac.universal_robots-0.3.2] startup
[8.685s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[8.693s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[8.697s] [ext: omni.kit.widget.imageview-1.0.3] startup
[8.698s] [ext: omni.kit.property.camera-1.0.3] startup
[8.701s] [ext: omni.kit.property.audio-1.0.6] startup
[8.705s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[8.778s] [ext: omni.isaac.diff_usd-1.0.1] startup
[8.782s] [ext: omni.kit.window.quicksearch-2.3.3] startup
[8.794s] [ext: omni.kit.property.render-1.1.0] startup
[8.796s] [ext: omni.kit.property.material-1.8.19] startup
[8.807s] [ext: omni.kit.property.light-1.0.6] startup
[8.810s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[8.819s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[8.836s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[8.840s] [ext: omni.kit.widgets.custom-1.0.4] startup
[8.872s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[8.873s] [ext: omni.kit.window.stage-2.3.12] startup
[8.879s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[8.901s] [ext: omni.curve.creator-104.1.2] startup
[8.908s] [ext: omni.anim.retarget.core-104.2.1] startup
[8.919s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[8.930s] [ext: omni.hydra.scene_api-0.1.1] startup
[8.935s] [ext: omni.curve.manipulator-104.7.3] startup
[8.973s] [ext: omni.graph.bundle.action-1.3.0] startup
[8.973s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[8.977s] [ext: omni.anim.graph.core-104.2.1] startup
[8.987s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[8.993s] [ext: omni.kit.property.transform-1.3.5] startup
[9.012s] [ext: omni.kit.property.skel-1.0.1] startup
[9.016s] [ext: omni.kit.property.geometry-1.2.2] startup
[9.023s] [ext: omni.anim.graph.ui-104.2.0] startup
[9.073s] [ext: omni.kit.property.bundle-1.2.6] startup
[9.076s] [ext: omni.isaac.examples-1.5.6] startup
[10.040s] [ext: omni.graph.window.core-1.43.3] startup
[10.077s] [ext: omni.slangnode-104.2.3] startup
[10.090s] [ext: omni.anim.graph.bundle-104.2.0] startup
[10.091s] [ext: omni.vdb_timesample_editor-0.1.5] startup
[10.096s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-06-02 07:25:42 [10,061ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[10.097s] [ext: omni.graph.window.generic-1.3.15] startup
[10.101s] [ext: omni.activity.freeze_monitor-1.0.1] startup
[10.106s] [ext: omni.isaac.examples_nodes-0.1.0] startup
[10.150s] [ext: omni.flowusd-104.2.4] startup
[10.180s] [ext: omni.kit.tool.asset_importer-2.4.0] startup
[10.194s] [ext: omni.anim.skelJoint-104.2.22] startup
[10.200s] [ext: omni.graph.window.action-1.5.5] startup
[10.203s] [ext: omni.isaac.gain_tuner-0.1.1] startup
[10.208s] [ext: omni.anim.retarget.ui-104.2.0] startup
[10.230s] [ext: omni.kit.pointclouds-0.0.16] startup
[10.238s] [ext: omni.isaac.kit-1.4.1] startup
[10.241s] [ext: omni.isaac.merge_mesh-0.1.2] startup
[10.245s] [ext: omni.anim.retarget.bundle-104.2.0] startup
[10.246s] [ext: omni.activity.pump-1.0.0] startup
[10.248s] [ext: omni.isaac.mjcf-0.3.1] startup
[10.257s] [ext: omni.activity.usd_resolver-1.0.1] startup
[10.259s] [ext: omni.isaac.occupancy_map-0.2.7] startup
[10.275s] [ext: omni.isaac.articulation_inspector-0.1.3] startup
[10.281s] [ext: omni.activity.ui-1.0.20] startup
[10.301s] [ext: omni.isaac.scene_blox-0.1.0] startup
[10.302s] [ext: omni.isaac.shapenet-2.0.1] startup
[10.318s] [ext: omni.isaac.synthetic_recorder-1.5.0] startup
[10.325s] [ext: omni.isaac.unit_converter-0.1.6] startup
[10.330s] [ext: omni.kit.widget.calendar-1.0.5] startup
[10.333s] [ext: omni.kit.ngsearch-0.0.10] startup
2023-06-02 07:25:42 [10,491ms] [Warning] [idl.telemetry.opentelemetry] opentelemetry package is not available, context propagation will be disabled
[10.575s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[10.577s] [ext: omni.kit.menu.stage-1.2.1] startup
[10.580s] [ext: omni.kit.tool.collect-2.1.20] startup
[10.593s] [ext: omni.kit.widget.extended_searchfield-1.0.17] startup
[10.625s] [ext: omni.isaac.urdf-0.5.9] startup
[10.666s] [ext: omni.kit.actions.window-1.1.0] startup
[10.685s] [ext: omni.isaac.window.about-1.1.0] startup
[10.688s] [ext: omni.kit.browser.asset-1.2.3] startup
[10.692s] [ext: omni.kit.browser.deepsearch-1.0.20] startup
[10.700s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[10.704s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[10.722s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[10.728s] [ext: omni.kit.selection-0.1.0] startup
[10.731s] [ext: omni.kit.importer.cad-0.3.4] startup
[10.782s] [ext: omni.isaac.extension_templates-1.0.0] startup
[10.787s] [ext: omni.kit.menu.aov-1.1.3] startup
[10.790s] [ext: omni.scene.visualization.ui-104.0.6] startup
[10.798s] [ext: omni.kit.menu.edit-1.1.6] startup
[10.806s] [ext: omni.kit.core.collection-0.1.1] startup
[10.812s] [ext: omni.kit.menu.file-1.1.4] startup
[10.815s] [ext: omni.services.facilities.base-1.0.2] startup
[10.817s] [ext: omni.scene.visualization.bundle-104.0.1] startup
[10.817s] [ext: omni.kit.profiler.window-2.0.5] startup
[10.837s] [ext: omni.kit.property.collection-0.1.10] startup
[10.839s] [ext: omni.kit.property.isaac-0.2.0] startup
[10.844s] [ext: omni.services.core-1.3.0] startup
[11.016s] [ext: omni.kit.renderer.cuda_interop-1.0.0] startup
[11.018s] [ext: omni.kit.property.sbsar-0.9.9] startup
[11.027s] [ext: omni.kit.quicksearch.actions-0.8.11] startup
[11.033s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[11.035s] [ext: omni.kit.quicksearch.hdri-0.8.11] startup
[11.037s] [ext: omni.services.transport.server.base-1.1.0] startup
[11.039s] [ext: omni.kit.livestream.core-0.0.0] startup
[11.042s] [ext: omni.kit.quicksearch.material-0.8.10] startup
[11.045s] [ext: omni.kit.quicksearch.props-0.8.6] startup
[11.047s] [ext: omni.kit.quicksearch.menu-0.8.7] startup
[11.050s] [ext: omni.isaac.asset_browser-0.2.4] startup
[11.053s] [ext: omni.services.transport.server.http-1.1.2] startup
[11.100s] [ext: omni.kit.livestream.websocket-2.6.6] startup
2023-06-02 07:25:43 [11,068ms] [Warning] [omni.livestream-websocket.plugin] Starting websocket server on :8900 port.
2023-06-02 07:25:43 [11,068ms] [Warning] [omni.livestream-websocket.plugin] WebSocket server listening on port 8900
2023-06-02 07:25:43 [11,068ms] [Warning] [omni.livestream-websocket.plugin] Streaming server started.
[11.104s] [ext: omni.services.transport.client.base-1.2.1] startup
[11.106s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[11.108s] [ext: omni.rtx.window.settings-0.6.2] startup
[11.121s] [ext: omni.services.streaming.manager-0.3.6] startup
[11.130s] [ext: omni.kit.quicksearch.settings-0.8.6] startup
[11.133s] [ext: omni.isaac.physics_inspector-0.1.3] startup
[11.138s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[11.138s] [ext: omni.services.streamclient.websocket-1.4.5] startup
[11.152s] [ext: omni.services.client-0.4.0] startup
[11.155s] [ext: omni.kit.agent-0.1.5] startup
[11.158s] [ext: omni.kit.thumbnails.mdl-1.0.20] startup
[11.165s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[11.170s] [ext: omni.services.transport.client.http_async-1.3.2] startup
[11.173s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[11.178s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[11.181s] [ext: omni.kit.window.toolbar-1.4.0] startup
[11.185s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[11.189s] [ext: omni.kit.browser.material-1.3.3] startup
[11.197s] [ext: omni.kit.window.material_graph-1.6.15] startup
[11.227s] [ext: omni.kit.thumbnails.images-0.2.3] startup
[11.234s] [ext: omni.kit.thumbnails.usd-0.5.2] startup
[11.242s] [ext: omni.kit.manipulator.camera-104.0.23] startup
[11.242s] [ext: omni.kit.manipulator.prim-104.10.7] startup
[11.260s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[11.260s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[11.262s] [ext: omni.kit.window.material-1.1.3] startup
[11.279s] [ext: omni.physx.commands-104.2.4-5.1] startup
[11.299s] [ext: omni.kit.viewport.menubar.camera-104.1.9] startup
[11.313s] [ext: omni.kit.viewport.menubar.render-104.0.20] startup
[11.320s] [ext: omni.kit.viewport.menubar.settings-104.3.5] startup
[11.332s] [ext: omni.kit.tool.asset_exporter-1.2.0] startup
[11.340s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[11.343s] [ext: omni.kit.tool.remove_unused.controller-0.1.2] startup
[11.345s] [ext: omni.physx.ui-104.2.4-5.1] startup
[11.423s] [ext: omni.kit.usda_edit-1.1.10] startup
[11.543s] [ext: omni.kit.viewport.actions-104.0.3] startup
[11.549s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[11.549s] [ext: omni.kit.viewport.menubar.lighting-104.0.9] startup
[11.558s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[11.559s] [ext: omni.kit.widget.collection-0.1.11] startup
[11.570s] [ext: omni.kit.property.physx-0.1.0] startup
[11.606s] [ext: omni.physx.demos-104.2.4-5.1] startup
[11.615s] [ext: omni.kit.viewport.ready-1.0.2] startup
[11.616s] [ext: omni.kit.viewport_widgets_manager-1.0.6] startup
[11.621s] [ext: omni.kit.widget.live-2.0.3] startup
2023-06-02 07:25:43 [11,590ms] [Warning] [omni.kit.widget.live.cache_state_menu] Unable to detect Omniverse Cache Server. Consider installing it for better IO performance.
[11.626s] [ext: omni.kit.mesh.raycast-104.3.2] startup
[11.633s] [ext: omni.kit.window.collection-0.1.11] startup
[11.636s] [ext: omni.kit.window.commands-0.2.4] startup
[11.640s] [ext: omni.physx.camera-104.2.4-5.1] startup
[11.650s] [ext: omni.physx.cct-104.2.4-5.1] startup
[11.663s] [ext: omni.physx.supportui-104.2.4-5.1] startup
[11.692s] [ext: omni.physx.vehicle-104.2.4-5.1] startup
[11.727s] [ext: omni.paint.system.core-104.5.8] startup
[11.845s] [ext: omni.kit.scripting-104.2.2] startup
2023-06-02 07:25:44 [11,809ms] [Warning] [omni.ext.plugin] [ext: omni.kit.scripting-104.2.2] '/isaac-sim/extscache/omni.kit.scripting-104.2.2+104.2.lx64.r.cp37/bin' in '[[native.plugin]]' was not found.
[11.862s] [ext: omni.kit.search.files-1.0.4] startup
[11.866s] [ext: omni.isaac.physics_utilities-0.1.1] startup
[11.873s] [ext: omni.kit.window.console-0.2.3] startup
[11.883s] [ext: omni.videoencoding-0.1.0] startup
[11.889s] [ext: omni.kit.window.imageviewer-1.0.6] startup
[11.895s] [ext: omni.paint.system.ui-104.3.14] startup
[11.923s] [ext: omni.physx.bundle-104.2.4-5.1] startup
[11.923s] [ext: omni.kit.sequencer.usd-103.3.1] startup
[11.931s] [ext: omni.iray.settings.core-0.6.4] startup
[11.939s] [ext: omni.kit.capture.viewport-1.1.24] startup
[11.953s] [ext: omni.rtx.settings.core-0.5.8] startup
[11.972s] [ext: omni.physx.zerogravity-104.2.4-5.1] startup
[11.991s] [ext: omni.kit.preferences.time-0.2.0] startup
[11.996s] [ext: omni.kit.property.sequence-0.2.0] startup
[12.000s] [ext: omni.kit.sequencer.core-103.3.0] startup
[12.007s] [ext: omni.particle.system.core-104.7.19] startup
[12.033s] [ext: omni.kit.window.movie_capture-2.1.8] startup
[12.061s] [ext: omni.paint.brush.scatter-104.2.12] startup
[12.080s] [ext: omni.kit.window.privacy-0.1.0] startup
[12.081s] [ext: omni.kit.window.script_editor-1.7.2] startup
[12.086s] [ext: omni.kit.window.sequencer-103.3.4] startup
[12.163s] [ext: omni.graph.window.particle.system-104.5.3] startup
[12.177s] [ext: omni.paint.brush.attributes-1.1.2] startup
[12.186s] [ext: omni.paint.brush.modify-104.3.2] startup
[12.195s] [ext: omni.paint.brush.scripting-104.7.0] startup
[12.212s] [ext: omni.scene.optimizer.core-104.1.5] startup
[12.220s] [ext: omni.paint.brush.select-104.3.2] startup
[12.232s] [ext: omni.particle.system.ui-104.5.1] startup
[12.252s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.2] startup
[12.275s] [ext: omni.kit.window.status_bar-0.1.5] startup
[12.279s] [ext: omni.kit.window.usd_paths-1.0.4] startup
[12.284s] [ext: omni.scene.optimizer.ui-104.1.5] startup
[12.292s] [ext: omni.paint.system.bundle-104.8.26] startup
[12.293s] [ext: omni.particle.system.bundle-104.2.24] startup
[12.293s] [ext: omni.replicator.composer-1.2.10] startup
[12.309s] [ext: omni.replicator.isaac-1.7.4] startup
[12.373s] [ext: omni.resourcemonitor-1.0.0] startup
[12.381s] [ext: omni.scene.optimizer.bundle-104.1.5] startup
[12.381s] [ext: omni.kit.search.service-0.1.5] startup
[12.390s] [ext: omni.services.starfleet.auth-0.1.4] startup
[12.402s] [ext: omni.services.usd-1.1.0] startup
[12.405s] [ext: omni.tools.array-104.0.12] startup
[12.436s] [ext: omni.mdl.usd_converter-1.0.0] startup
MDL python binding about to load ...
MDL python binding loaded
[omni.mdl.usd_converter] MDL to USD converter startup
[12.455s] [ext: omni.tools.pivot-104.1.0] startup
[12.473s] [ext: omni.anim.shared-104.14.1] startup
[12.489s] [ext: omni.tools.randomizer-104.0.9] startup
[12.511s] [ext: omni.kit.quicklayout-1.1.1] startup
[12.516s] [ext: omni.kit.window.title-1.1.2] startup
2023-06-02 07:25:44 [12,482ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-06-02 07:25:44 [12,482ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
2023-06-02 07:25:44 [12,483ms] [Warning] [carb] [Plugin: libomni.structuredlog.plugin.so] Module /isaac-sim/kit/libomni.structuredlog.plugin.so remained loaded after unload request
2023-06-02 07:25:44 [12,484ms] [Warning] [carb.windowing-glfw.plugin] GLFW initialization failed.
2023-06-02 07:25:44 [12,484ms] [Warning] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.3]) (impl: carb.windowing-glfw.plugin)
[12.521s] [ext: semantics.schema.editor-0.3.3] startup
[12.530s] [ext: omni.kit.stage.mdl_converter-1.0.1] startup
[12.533s] [ext: omni.isaac.robot_description_editor-2.1.1] startup
[12.542s] [ext: omni.anim.timeline-104.0.7] startup
[12.547s] [ext: omni.isaac.onshape-0.6.2] startup
[13.537s] [ext: omni.kit.window.stats-0.1.2] startup
[13.540s] [ext: omni.isaac.app.setup-0.8.1] startup
[13.546s] Isaac Sim Headless Websocket Version: 2022.2.1-rc.14
[13.558s] [ext: omni.isaac.ros_bridge-1.11.2] startup
2023-06-02 07:25:45 [13,549ms] [Warning] [omni.isaac.ros_bridge.scripts.extension] ROS_MASTER_URI not set, using default, ROS_MASTER_URI=http://localhost:11311
[13.613s] [ext: omni.isaac.assets_check-0.3.2] startup
[13.624s] [ext: omni.isaac.sim.base-2022.2.1] startup
[13.624s] [ext: omni.isaac.sim.headless.websocket-2022.2.1] startup
[14.026s] [ext: omni.isaac.sim.headless.websocket-2022.2.1] shutdown
[14.026s] [ext: omni.isaac.sim.base-2022.2.1] shutdown
[14.026s] [ext: omni.isaac.examples_nodes-0.1.0] shutdown
[14.270s] [ext: omni.isaac.examples-1.5.6] shutdown
[14.521s] [ext: omni.isaac.universal_robots-0.3.2] shutdown
[14.778s] [ext: omni.isaac.cortex-0.3.2] shutdown
[15.035s] [ext: omni.isaac.franka-0.4.0] shutdown
[15.275s] [ext: omni.isaac.dofbot-0.3.0] shutdown
[15.517s] [ext: omni.isaac.manipulators-1.1.0] shutdown
[15.765s] [ext: omni.isaac.demos-0.3.3] shutdown
[17.274s] [ext: omni.isaac.surface_gripper-0.4.0] shutdown
2023-06-02 07:25:49 [17,686ms] [Warning] [omni.ext._impl._internal] omni.isaac.surface_gripper-0.4.0 -> <class 'omni.isaac.surface_gripper.scripts.extension.Extension'>: extension object is still alive, something holds a reference on it. References: ["[0]:type: <class 'method'>, id: 139905697623248"]
[17.963s] [ext: omni.isaac.wheeled_robots-0.6.3] shutdown
[18.218s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[18.235s] [ext: omni.isaac.manipulators-1.1.0] startup
[18.236s] [ext: omni.isaac.franka-0.4.0] startup
[18.237s] [ext: omni.isaac.cortex-0.3.2] startup
[18.238s] [ext: omni.isaac.demos-0.3.3] startup
[18.251s] [ext: omni.isaac.dofbot-0.3.0] startup
[18.252s] [ext: omni.isaac.universal_robots-0.3.2] startup
[18.253s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[18.262s] [ext: omni.isaac.examples-1.5.6] startup
[18.388s] [ext: omni.isaac.examples_nodes-0.1.0] startup
[18.391s] [ext: omni.isaac.sim.base-2022.2.1] startup
[18.392s] [ext: omni.isaac.sim.headless.websocket-2022.2.1] startup
[18.484s] app ready
[23.573s] RTX ready
[23.584s] Isaac Sim Headless Websocket App is loaded.
Browser
I am using Google Chrome
Device
I am running docker from a Mac connected via ssh to a Linux workstation which is in the same local network.
WebRTC
WebRTC does not work
Thanks for the additional info.
The log looks like you are running WebSocket mode. Please see Livestream Clients — Omniverse Robotics documentation
Try the openh264 flag for websocket too. Try WebRTC too if possible.
Also share the error on the browser if it does not connect. Try a different browser is Chrome does not work.
Hey everyone, I struggled with this exact same ‘grey screen / no display’ issue on RunPod/Cloud for weeks. It turns out the native WebRTC UDP stream just cannot work through standard TCP proxies.
I finally built a solid workaround using noVNC that runs the full Isaac Sim GUI smoothly in the browser over a single HTTP port.
I posted the full explanation and the GitHub repo solution here: Running Isaac Sim in a browser on TCP-only clouds (RunPod): WebRTC livestream can't work — here's a noVNC approach that does
Hope this saves you the effort I went through last two weeks!
Hi @Sa3d-99, thanks for sharing your findings and the noVNC workaround here – that’s genuinely useful for anyone hitting this issue on TCP-only cloud providers.
We’re continuing the conversation in your new topic: Running Isaac Sim in a browser on TCP-only clouds, where we’ve also filed an internal ticket for the port-80 connectivity check issue you reported.
