I am trying iot-sample, but when I run the Usd.Stage.Open function in app.py for each of ingest_app_csv and ingest_app_mqtt, I get an error.
The error message “The specified file cannot be found” is displayed.
Can someone please tell me how to solve this problem?
ーーLog messages–
---- LOG MESSAGES —
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘Connection library (version 0x000b001400000000, protocol version 1.19) settings:’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ Transfer settings:‘)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ contentBufferSize = 1073741824’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ receiveBufferSize = 268435456’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ transmitBufferSize = 1073741824’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ maxTransferConnectionCount = 10’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ parallelTransferChunkSize = 1048576’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ lftContentBufferSize = 1073741824’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ Log settings:‘)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logFile = 1’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logTickStatistics = 0’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logIncomingMessages = 1’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ’ logOutgoingMessages = 1’)
(‘Main’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘OmniTrace dll/so not loaded’)
(‘Main’, ‘provider_nucleus’, LogLevel.INFO, ‘Initialized Nucleus API v11.20-4c89d0de’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 1: copy(file:D:\Projects\OmniverseProjects\iotSample\iot-samples\content/ConveyorBelt_A08_PR_NVD_01 => omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01)’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Starting’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(wss://localhost/omni/discovery): Searching for services’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6F730 connecting to wss://localhost/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to wss://localhost:443/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192C939D20 not using mTLS since client certificate and private key were not provided’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=1 DiscoverySearch.find 000002192DACEB68’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=2 DiscoverySearch.find 000002192DACEB68’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=3 DiscoverySearch.find 000002192DACEB68’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=4 DiscoverySearch.find 000002192DACF348’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost/omni/discovery): Searching for services’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6F280 connecting to ws://localhost/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to ws://localhost:80/omni/discovery’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=1 DiscoverySearch.find 000002192DACF348’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=4 DiscoverySearch.find 000002192DACEB68’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost:3333): Searching for services’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6DFC0 connecting to ws://localhost:3333’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to ws://localhost:3333/’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=2 DiscoverySearch.find 000002192DACF348’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=3 DiscoverySearch.find 000002192DACF348’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 1: Stat(file:/D:/Projects/OmniverseProjects/iotSample/iot-samples/content/ConveyorBelt_A08_PR_NVD_01) returned Ok’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192DAD00B0 Upgraded to WebSocket’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=1 {“found”: true, “version”: 2, “service_interface”: {“origin”: “OmniAuth.idl.ts”, “name”: “Credentials”, “capabilities”: {“get_settings”: 0, “auth”: 2, “register”: 3, “reset”: 2}}, “transport”: {“name”: “sows”, “params”: “{\“host\”: \“127.0.0.1\”, \“port\”: 3100}”, “meta”: {“marshaller”: “bs”, “serializer”: “json”, “ssl”: “false”}}, “meta”: {“deployment”: “external”, “version”: “1.5.2”, “login_url”: "http://:3180"}}#')
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost:3333): Found Auth::Credentials service using transport 'sows' {“host”: “127.0.0.1”, “port”: 3100}’)
(‘Tick’, ‘discovery’, LogLevel.INFO, 'Discovery(ws://localhost:3333): Found auth login_url http://:3180’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=2 {“found”: true, “version”: 2, “service_interface”: {“origin”: “OmniAuth.idl.ts”, “name”: “Tokens”, “capabilities”: {“generate”: 2, “refresh”: 1, “invalidate”: 0, “subscribe”: 0, “create_api_token”: 2, “delete_api_token”: 0, “get_api_tokens”: 0, “auth_with_api_token”: 1}}, “transport”: {“name”: “sows”, “params”: “{\“host\”: \“127.0.0.1\”, \“port\”: 3100}”, “meta”: {“marshaller”: “bs”, “serializer”: “json”, “ssl”: “false”}}, “meta”: {“deployment”: “external”, “version”: “1.5.2”, “login_url”: “http://:3180"}}#')
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Auth::Tokens found!’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Auth::Tokens supports subscribe!’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, '>> id=3 {“found”: true, “version”: 2, “service_interface”: {“origin”: “OmniAuth.idl.ts”, “name”: “DeviceFlow”, “capabilities”: {“authorize”: 0, “submit”: 0, “token”: 0}}, “transport”: {“name”: “sows”, “params”: “{\“host\”: \“127.0.0.1\”, \“port\”: 3100}”, “meta”: {“marshaller”: “bs”, “serializer”: “json”, “ssl”: “false”}}, “meta”: {“deployment”: “external”, “version”: “1.5.2”, “login_url”: "http://:3180”}}#’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Auth::DeviceFlow found!’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=4 {“found”: true, “version”: 2, “service_interface”: {“origin”: “omni1.idl.ts”, “name”: “Connection”, “capabilities”: {“add_user_to_group”: 0, “auth”: 5, “authorize_token”: 4, “change_acl”: 0, “checkpoint_version”: 2, “copy”: 2, “copy2”: 2, “create”: 2, “create_asset”: 2, “create_asset_with_hash”: 2, “create_directory”: 1, “create_group”: 0, “create_object”: 2, “deep_copy_object_struct”: 0, “delete”: 0, “delete2”: 1, “get_acl”: 0, “get_acl_resolved”: 0, “get_acl_v2”: 0, “get_branches”: 1, “get_checkpoints”: 1, “get_group_users”: 0, “get_groups”: 0, “get_mount_info”: 0, “get_transaction_id”: 0, “get_user_groups”: 0, “get_users”: 0, “list”: 5, “list2”: 5, “lock”: 3, “mount”: 0, “ping”: 0, “read”: 2, “read_asset_resolved”: 0, “read_asset_version”: 0, “read_object_resolved”: 0, “read_object_version”: 0, “remove_group”: 0, “remove_user_from_group”: 0, “rename”: 2, “rename2”: 1, “rename_group”: 0, “replace_version”: 1, “service_resolve_acl”: 2, “service_subscribe_list”: 1, “set_acl_v2”: 0, “set_path_options”: 1, “set_path_options2”: 0, “set_user_agent”: 0, “stat2”: 2, “subscribe_list”: 4, “subscribe_read_asset”: 2, “subscribe_read_object”: 3, “subscribe_server_notifications”: 0, “unlock”: 2, “unmount”: 0, “update”: 1, “update_asset”: 2, “update_asset_with_hash”: 2, “update_object”: 2, “stop”: 0}}, “transport”: {“name”: “connlib”, “params”: “{\n \“url\”: \“ws://127.0.0.1:3009\”\n}”, “meta”: {}}, “meta”: {“deployment”: “external”}}#’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost:3333): Api::Connection found!’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost:3333): Found Nucleus API ws://127.0.0.1:3009’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘receive error: 10057’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192DAD3190 Terminating connection (socket closed)’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(ws://localhost/omni/discovery): Auth::Credentials search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost/omni/discovery): Auth::Tokens search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost/omni/discovery): Auth::DeviceFlow search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(ws://localhost/omni/discovery): Api::Connection search failed: Connection is terminated’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192DAD3190 Sending CLOSE (reason=1000)’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘ssl send error: 10057’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021963EA2740 Terminating connection (socket closed)’)
(‘Tick’, ‘discovery’, LogLevel.INFO, ‘Discovery(wss://localhost/omni/discovery): Auth::Credentials search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(wss://localhost/omni/discovery): Auth::Tokens search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(wss://localhost/omni/discovery): Auth::DeviceFlow search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(wss://localhost/omni/discovery): Api::Connection search failed: Connection is terminated’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Completed’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Stopping’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6F280 destroyed’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6DFC0 destroyed’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192DAD00B0 Sending CLOSE (reason=1000)’)
(‘Tick’, ‘discovery’, LogLevel.DEBUG, ‘Discovery(localhost): Calling Callback’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Using username/password from environment variables for omniverse://localhost’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘Starting’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6EAB0 connecting to ws://127.0.0.1:3100’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘connecting to ws://127.0.0.1:3100/’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘<< id=1 Credentials.auth 000002192DACEC88’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6F730 destroyed’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘0000021963EA2740 Sending CLOSE (reason=1000)’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192DAD0390 Upgraded to WebSocket’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘>> id=1 {“status”: “OK”, “version”: 2, “access_token”: “eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJ0ZXN0IiwicHJvZmlsZSI6eyJmaXJzdF9uYW1lIjoidGVzdCIsImxhc3RfbmFtZSI6InRlc3QiLCJlbWFpbCI6Im1zb2dhQGR4Yy5jb20iLCJhZG1pbiI6dHJ1ZSwibnVjbGV1c19ybyI6ZmFsc2UsInJlYWRvbmx5IjpmYWxzZSwicHJvdmlkZXIiOiJJbnRlcm5hbCIsImVuYWJsZWQiOnRydWUsImFjdGl2YXRlZCI6dHJ1ZX0sImp0aSI6ImZkOTExYjhiYzc2MzRmNDlhNjE4YWZjZWMyYjIxM2RlIiwiaWF0IjoxNzIwNjE2OTU4LCJleHAiOjE3MjA3MDMzNTh9.OgLcHgUceebMwGe_pHAkjYgKdmE8vm1nbxeGZjbKBQgD1IyUzslPVLCG_7alhaUzoIuhN6gFJX9X18Ufw-WJjw”, “refresh_token”: “eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJ0ZXN0IiwicHJvZmlsZSI6eyJmaXJzdF9uYW1lIjoidGVzdCIsImxhc3RfbmFtZSI6InRlc3QiLCJlbWFpbCI6Im1zb2dhQGR4Yy5jb20iLCJhZG1pbiI6dHJ1ZSwibnVjbGV1c19ybyI6ZmFsc2UsInJlYWRvbmx5IjpmYWxzZSwicHJvdmlkZXIiOiJJbnRlcm5hbCIsImVuYWJsZWQiOnRydWUsImFjdGl2YXRlZCI6dHJ1ZX0sImp0aSI6ImUzNDZlZWQ5ZjIzMzRiY2VhMTFhNWU3ZGI4MmU1M2NhIiwiaWF0IjoxNzIwNjE2OTU4LCJleHAiOjE3MjMyMDg5NTh9.IuXa9SgzfYNgskI–iUk5-bDCWl1WGk-EmMc37Fj80tahjC5lwfVYebyLP55-o0MFq93v_IvFy5jN03z_AOzFA”, “username”: “test”, “profile”: {“first_name”: “test”, “last_name”: “test”, “email”: “msoga@dxc.com”, “admin”: true, “provider”: “Internal”, “readonly”: false, “nucleus_ro”: false, “enabled”: true, “activated”: true}}#’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Auth: Retrieved token for user “test”’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘0000021963978EF0 connecting to ws://127.0.0.1:3009’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘connecting to ws://127.0.0.1:3009/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘Created connection 000002192DB90A80’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“client_capabilities”:{“add_user_to_group”:0,“auth”:5,“authorize_token”:4,“change_acl”:0,“checkpoint_version”:2,“copy”:2,“copy2”:2,“create”:2,“create_asset”:2,“create_asset_with_hash”:2,“create_directory”:1,“create_group”:0,“create_object”:2,“deep_copy_object_struct”:0,“delete”:0,“delete2”:1,“get_acl”:0,“get_acl_resolved”:0,“get_acl_v2”:0,“get_branches”:1,“get_checkpoints”:1,“get_group_users”:0,“get_groups”:0,“get_mount_info”:0,“get_transaction_id”:0,“get_user_groups”:0,“get_users”:0,“list”:5,“list2”:5,“lock”:3,“mount”:0,“ping”:0,“read”:2,“read_asset_resolved”:0,“read_asset_version”:0,“read_object_resolved”:0,“read_object_version”:0,“remove_group”:0,“remove_user_from_group”:0,“rename”:2,“rename2”:1,“rename_group”:0,“replace_version”:1,“service_resolve_acl”:2,“service_subscribe_list”:1,“set_acl_v2”:0,“set_path_options”:1,“set_path_options2”:0,“set_user_agent”:0,“stat2”:2,“subscribe_list”:4,“subscribe_read_asset”:2,“subscribe_read_object”:3,“subscribe_server_notifications”:0,“unlock”:2,“unmount”:0,“update”:1,“update_asset”:2,“update_asset_with_hash”:2,“update_object”:2},“command”:“authorize_token”,“id”:1,“token”:“eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJzdWIiOiJ0ZXN0IiwicHJvZmlsZSI6eyJmaXJzdF9uYW1lIjoidGVzdCIsImxhc3RfbmFtZSI6InRlc3QiLCJlbWFpbCI6Im1zb2dhQGR4Yy5jb20iLCJhZG1pbiI6dHJ1ZSwibnVjbGV1c19ybyI6ZmFsc2UsInJlYWRvbmx5IjpmYWxzZSwicHJvdmlkZXIiOiJJbnRlcm5hbCIsImVuYWJsZWQiOnRydWUsImFjdGl2YXRlZCI6dHJ1ZX0sImp0aSI6ImZkOTExYjhiYzc2MzRmNDlhNjE4YWZjZWMyYjIxM2RlIiwiaWF0IjoxNzIwNjE2OTU4LCJleHAiOjE3MjA3MDMzNTh9.OgLcHgUceebMwGe_pHAkjYgKdmE8vm1nbxeGZjbKBQgD1IyUzslPVLCG_7alhaUzoIuhN6gFJX9X18Ufw-WJjw”,“version”:“1.19”}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘Stopping’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192CD6EAB0 destroyed’)
(‘Tick’, ‘idl’, LogLevel.VERBOSE, ‘000002192DAD0390 Sending CLOSE (reason=1000)’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘000002192DAD17B0 Upgraded to WebSocket’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“server_capabilities”:{“add_user_to_group”:0,“auth”:5,“authorize_token”:4,“change_acl”:0,“checkpoint_version”:2,“copy”:2,“copy2”:2,“create”:2,“create_asset”:2,“create_asset_with_hash”:2,“create_directory”:1,“create_group”:0,“create_object”:2,“deep_copy_object_struct”:0,“delete”:0,“delete2”:1,“get_acl”:0,“get_acl_resolved”:0,“get_acl_v2”:0,“get_branches”:1,“get_checkpoints”:1,“get_group_users”:0,“get_groups”:0,“get_mount_info”:0,“get_transaction_id”:0,“get_user_groups”:0,“get_users”:0,“list”:5,“list2”:5,“lock”:3,“mount”:0,“ping”:0,“read”:2,“read_asset_resolved”:0,“read_asset_version”:0,“read_object_resolved”:0,“read_object_version”:0,“remove_group”:0,“remove_user_from_group”:0,“rename”:2,“rename2”:1,“rename_group”:0,“replace_version”:1,“service_resolve_acl”:2,“service_subscribe_list”:1,“set_acl_v2”:0,“set_path_options”:1,“set_path_options2”:0,“set_user_agent”:0,“stat2”:2,“subscribe_list”:4,“subscribe_read_asset”:2,“subscribe_read_object”:3,“subscribe_server_notifications”:0,“unlock”:2,“unmount”:0,“update”:1,“update_asset”:2,“update_asset_with_hash”:2,“update_object”:2},“ts”:{“omni_server_out_ts”:13353446084927899},“version”:"\“1.14.37-0959a9e9\” ",“username”:“test”,“token”:“O0DFK3AR3SW51EL4”,“connection_id”:“QX0UA0TIGLXCAIQX”,“connection_id_signature”:“28ab1ef742e4b1f3e2435b098752752d20d0c0b8cfade1ccd315117d1da5cca7”,“max_chunk_size”:134217728,“lft_address”:“http://127.0.0.1:3030”,“lft_threshold”:65536,“super_user”:true,“multipart_chunk_size”:5242880,“max_in_flight_requests”:0,“id”:1}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘Connected to omniverse://localhost as test’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘Connection ID: QX0UA0TIGLXCAIQX’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server is running version 1.14.37-0959a9e9’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘LFT Enabled. Threshold=64 KB, Server=http://127.0.0.1:3030’)
(‘Tick’, ‘provider_nucleus’, LogLevel.VERBOSE, ‘Server supports { { “add_user_to_group”, 0 }, { “auth”, 5 }, { “authorize_token”, 4 }, { “change_acl”, 0 }, { “checkpoint_version”, 2 }, { “copy”, 2 }, { “copy2”, 2 }, { “create”, 2 }, { “create_asset”, 2 }, { “create_asset_with_hash”, 2 }, { “create_directory”, 1 }, { “create_group”, 0 }, { “create_object”, 2 }, { “deep_copy_object_struct”, 0 }, { “delete”, 0 }, { “delete2”, 1 }, { “get_acl”, 0 }, { “get_acl_resolved”, 0 }, { “get_acl_v2”, 0 }, { “get_branches”, 1 }, { “get_checkpoints”, 1 }, { “get_group_users”, 0 }, { “get_groups”, 0 }, { “get_mount_info”, 0 }, { “get_transaction_id”, 0 }, { “get_user_groups”, 0 }, { “get_users”, 0 }, { “list”, 5 }, { “list2”, 5 }, { “lock”, 3 }, { “mount”, 0 }, { “ping”, 0 }, { “read”, 2 }, { “read_asset_resolved”, 0 }, { “read_asset_version”, 0 }, { “read_object_resolved”, 0 }, { “read_object_version”, 0 }, { “remove_group”, 0 }, { “remove_user_from_group”, 0 }, { “rename”, 2 }, { “rename2”, 1 }, { “rename_group”, 0 }, { “replace_version”, 1 }, { “service_resolve_acl”, 2 }, { “service_subscribe_list”, 1 }, { “set_acl_v2”, 0 }, { “set_path_options”, 1 }, { “set_path_options2”, 0 }, { “set_user_agent”, 0 }, { “stat2”, 2 }, { “subscribe_list”, 4 }, { “subscribe_read_asset”, 2 }, { “subscribe_read_object”, 3 }, { “subscribe_server_notifications”, 0 }, { “unlock”, 2 }, { “unmount”, 0 }, { “update”, 1 }, { “update_asset”, 2 }, { “update_asset_with_hash”, 2 }, { “update_object”, 2 } }’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server omniverse://localhost supports atomic checkpoints’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“omni_objects2”,“id”:2}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“versioning”,“id”:3}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ext_value_min_size”:262144,“id”:2}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server omniverse://localhost supports omni-objects and it is enabled’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“enabled”:true,“id”:3}’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Server omniverse://localhost supports checkpoints and it is enabled’)
(‘Tick’, ‘provider_nucleus’, LogLevel.INFO, ‘Connected to omniverse://localhost’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache miss! omniverse://localhost/Users/test/iot-samples/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_list”,“id”:4,“path”:{“branch”:“”,“path”:“/Users/test/iot-samples/”}}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“list2”,“id”:5,“path”:“/Users/test/iot-samples/”}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“LATEST”,“id”:4}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“OK”,“ts”:{“omni_server_out_ts”:13353446084929598},“entries”:[{“path”:“/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/”,“branch”:“default”,“acl”:[“admin”,“write”,“read”],“created_timestamp”:1720580316,“modified_timestamp”:1720580316,“path_type”:“folder”,“empty”:false,“mounted”:false,“created_by”:“test”,“modified_by”:“test”}],“id”:5}’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘>> {“status”:“DONE”,“ts”:{“omni_server_out_ts”:13353446084929627},“id”:5}’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 1: Stat(omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01) returned Ok’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 1: copy(file:D:\Projects\OmniverseProjects\iotSample\iot-samples\content/ConveyorBelt_A08_PR_NVD_01 => omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01) returned Error: Already Exists’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 5: resolve(omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache miss! omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/’)
(‘Tick’, ‘nucleus_connection’, LogLevel.VERBOSE, ‘<< {“command”:“subscribe_list”,“id”:6,“path”:{“branch”:“”,“path”:“/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/”}}’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 8: resolve(omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd)’)
(‘Tick’, ‘provider_nucleus’, LogLevel.DEBUG, ‘ListCache hit! omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 8: resolve(omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd): Found omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd’)
(‘Main’, ‘core’, LogLevel.VERBOSE, ‘Request 10: getLocalFile(omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd)’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 10: getLocalFile: omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd already exists as C:\Users\sogam\AppData\Local\ov\cache\client\omniverse\5c27f098c9acccb345ca357904455771bd1fdbdc90e8eba7614bd6bfc8fe24d9.usd, not downloading’)
(‘Tick’, ‘core’, LogLevel.VERBOSE, ‘Request 10: getLocalFile(omniverse://localhost/Users/test/iot-samples/ConveyorBelt_A08_PR_NVD_01/ConveyorBelt_A08_PR_NVD_01.usd): Ok C:\Users\sogam\AppData\Local\ov\cache\client\omniverse\5c27f098c9acccb345ca357904455771bd1fdbdc90e8eba7614bd6bfc8fe24d9.usd’)
(‘File IO’, ‘provider_file’, LogLevel.VERBOSE, ‘GetFileAttributesExW() returned “指定されたパスが見つかりません。”’)
