the error INFO is below:
12:04:28 DEBUG: running command < true >
12:04:28 INFO: command finished successfully
12:04:28 DEBUG: running command < lsusb | grep 0955:7019 >
12:04:28 INFO: Verified, 0955:7019 detected in recovery mode.
12:04:28 DEBUG: Device Mode Host Setup in Flash: using adapter to install NV_DEVICE_MODE_SETUP_IMAGE_COMP@JETSON_AGX_XAVIER to
12:04:29 INFO: Device Mode Host Setup in Flash: [ Component Install Started ]
12:04:29 INFO: Device Mode Host Setup in Flash: exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_IMAGE_COMP.sh
12:04:29 INFO: Device Mode Host Setup in Flash: Found route default enp0s3, setting up device mode
12:04:29 INFO: Device Mode Host Setup in Flash: net.ipv4.ip_forward = 1
12:04:29 INFO: Device Mode Host Setup in Flash: command finished successfully
12:04:29 SUMMARY: Device Mode Host Setup in Flash: Install completed successfully.
12:04:29 DEBUG: running command < true >
12:04:29 INFO: command finished successfully
12:04:30 DEBUG: Flash Jetson AGX Xavier 16GB/32GB: using adapter to install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER to
12:04:30 INFO: Flash Jetson AGX Xavier 16GB/32GB: sudo ./nvautoflash.sh
12:04:30 INFO: Flash Jetson AGX Xavier 16GB/32GB: *** Checking ONLINE mode … OK.
12:04:30 INFO: Flash Jetson AGX Xavier 16GB/32GB: *** Checking target board connection … 1 connections found.
12:04:30 INFO: Flash Jetson AGX Xavier 16GB/32GB: Put the target board in RCM mode and retry.
12:04:30 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ Component Install Finished with Error ]
12:04:30 ERROR: Flash Jetson AGX Xavier 16GB/32GB: command terminated with error
12:04:32 SUMMARY: NVIDIA Nsight Systems: Depends on failed component
