I am trying to flash a Jetson AGX Xavier with Jetpack 4.6. During the flashing process the sdk manager gives a feedback that the Jetson is not in force recovery mode even though it’s correctly detected and the procedure to put it in force recovery has been followed (tried multiple times). Also, no output is given through the hdmi port at any time (no nvidia logo, no wizard to set username and password…).
What can be the issue and what solutions could exist?
Dump the log and let log tells what is going on.
[0014.385] W> RATCHET: MB1 binary ratchet value 4 is too rge than ratchet level.
[0014.393] I> MB1 (prd-version: 1.5.1.7-t194-41334769-98030a79)
[0014.3] I> Boot-mode: Platform RCM
[0014.402] I> Chip revision : A0
[0014.405] I> Bootrom patch version : 15 (correctly patched)
[0014.410] I> ATE fuse revision : 0x200
[0014.414] I> Ram rair fuse : 0x0
[0014.417] I> Ram Code : 0x2
[0014.419] I> rssource : 0x0
[0014.422] I> rst_level : 0x0
[0014.426] I> USB configuration success
[0017.155] I> mb2 image downloaded
[0017.454] I> Recovery boot mode 0
[0017.491] I> Boot-device: eMMC
[0017.496] I> UPHY full init done
[0017.500] I> MB1 done
[0017.505] W> Profiler notnitialized
[0017.508] I> Welcome to MB2(TBoot-BPMP) Applet (vsion: 00.00.2018.32-mobile-78)
[0017.516] W> Profiler not initialid
[0017.519] I> DMA Heap @ [0x40020000 - 0x40065800]
[0017.5] I> Default Heap @ [0xd486400 - 0xd48a400]
[0017.529] W> Profiler not initialized
[0017.532] W> Profiler not inialized
[0017.536] E> DEVICE_PROD: Invalid value data = 0, siz= 0.
[0017.541] W> device prod register failed
[0017.545] W> Profiler not initialized
[0017.609] I> sdmmc DDR50 mode
[0017.613] I> No supported QSPI ash found
[0017.617] E> QSPI Flash: Insufficient flash size (MB)
[0017.622] I> QSPI Flash is not present.
[0017.674] E> Link startup dme_set failed
[0017.677] E> UFS itialization failed
[0017.681] I> UFS is not present
[0017.68 W> Profiler not initialized
[0017.690] I> Found 15 partitions in SDMMC_BOOT (instance 3)
017.699] I> Found 36 partitions in SDMMC_USER (instance 3)
[07.705] W> Profiler not initialized
[0017.708] W> Profiler not initiazed
[0017.712] W> Profiler not initialized
[0017.715] I> Enting 3p server
[0017.718] I> USB configuration success
[0019.449] I> Populate chip info
[0019.966] I> Populate eeprom info
[0020.039] I> Populate eeprom info for module cvm
[0027.425] I> Populate chip info
[0027.951] I> Populate eeprom info
[0028.022] I> Populate eeprom info for module cvb
[0028.716] I> Rebooting : reboot-recovery
[002
If you want to share any log, share the whole log instead of partial log and attach it as a text file.
For sdkmanager, click the “export logs” button on the sdkmanager gui and attach the zip file.
log.txt (2.1 MB)
These are the logs from the sdk manager
Use “export logs” button on sdkm and it shall be a zip file with lots of txt files… please directly attach the whole zip file here.
21:45:08.532 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: ###############################################################################
21:45:08.532 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: # L4T BSP Information:
21:45:08.532 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: # R32 , REVISION: 6.1
21:45:08.639 - error: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: Error: probing the target board failed.
21:45:08.640 - info: Event: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - error is: Error: probing the target board failed.
21:45:08.640 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: Make sure the target board is connected through
21:45:08.640 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: USB port and is in recovery mode.
21:45:08.640 - error: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: *** ERROR: flashing failed.
21:45:08.640 - info: Event: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS - error is: *** ERROR: flashing failed.
21:45:08.640 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [ Component Install Finished with Error ]
21:45:08.640 - info: NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: [host] [ 48.00 KB used. Disk Avail: 54.09 GB ]
The txt file you attached said your board is not in recovery mode at all. Or you didn’t plug the correct usb port.
Yes, but I followed the procedure and can see the jetson using lsusb
SDKM_logs_2021-12-08_20-16-05.zip (399.3 KB)
Followed what procedure?
Which port is in use to flash? Are you sure you use the correct type C?
Use this USB-C.
- Make sure the jetson is poweered off
- Hold the recovery button
- Hold the power button
- Release both buttons
I used the USB type C port on the same side as the micro USB and power LED
Please do not release both buttons. Just release the power button first and then the recovery button.
I tried that with the same result.
Do you have other usb cable and host to test? or even other jetson AGX devkit to test? If more than one jetson cannot get flashed with this host/cable, then it is mostly likely due to the host/usb cable.
Not able to flash board is pure hardware problem, nothing from software side can configure/fix this.
We’ll try with an other cable. Unfortunately we do not have a second Nvidia Jetson AGX Xavier Developper Kit, although we would be happy to.
If it actyally is a pure hardware problem, what are our options moving forwards ?
Is your host machine a ubuntu from VM?
We tried both with the same results.
What both?
VM and dualboot
