i have a jetpack 4.2 in my xavier, and i want to flash a jetpack4.4 to remove the old one.
when i use sdkmanager to flash it, i got the following error.
i have connected xavier with host PC and set xavier to recovery mode
Bus 001 Device 018: ID 0955:7019 NVidia Corp.
can anybody help me?
17:44:18 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: Error: probing the target board failed.
17:44:18 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: Make sure the target board is connected through
17:44:18 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: USB port and is in recovery mode.
17:44:18 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: [ Component Install Finished with Error ]
17:44:18 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: [host] [ 0.00 B released. Disk Avail: 72.71 GB ]
17:44:18 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 6s ]
17:44:18 ERROR: Flash Jetson AGX Xavier 16GB/32GB - flash: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh; [error]:
17:44:18 ERROR: Flash Jetson AGX Xavier 16GB/32GB - flash: command terminated with error
17:44:18 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB - flash: First Error: Installation failed.
18:02:30 DEBUG: Flash Jetson AGX Xavier 16GB/32GB - flash: using adapter to install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER to /home/yang/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
18:02:30 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: change working directory to /home/yang/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
18:02:30 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: sudo ./flash.sh jetson-xavier mmcblk0p1
18:02:30 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: # L4T BSP Information:
18:02:30 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: ###############################################################################
18:02:36 INFO: Flash Jetson AGX Xavier 16GB/32GB - flash: USB port and is in recovery mode.
18:02:36 ERROR: Flash Jetson AGX Xavier 16GB/32GB - flash: command terminated with error
