I am new to The Jetson device, and am trying to install it for the first time. I continually get this error in the logs:
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: sudo ./flash.sh jetson-xavier mmcblk0p1
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: fi
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: sleep 20
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: **********************
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: exec_command: /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: ###############################################################################
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: # L4T BSP Information:
15:12:36 INFO: Flash Jetson AGX Xavier 16GB/32GB: # R32 , REVISION: 4.3
15:12:42 INFO: Flash Jetson AGX Xavier 16GB/32GB: Error: probing the target board failed.
15:12:42 INFO: Flash Jetson AGX Xavier 16GB/32GB: Make sure the target board is connected through
15:12:42 INFO: Flash Jetson AGX Xavier 16GB/32GB: USB port and is in recovery mode.
15:12:42 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ Component Install Finished with Error ]
15:12:42 INFO: Flash Jetson AGX Xavier 16GB/32GB: [host] [ 20.00 KB used. Disk Avail: 301.29 GB ]
15:12:42 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 5s ]
15:12:42 ERROR: Flash Jetson AGX Xavier 16GB/32GB: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh; [error]:
15:12:42 ERROR: Flash Jetson AGX Xavier 16GB/32GB: command terminated with error
15:12:42 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB: Failed to execute commands with GenericInstaller
I am at a complete loss as to what to try next. I have not tried the factory reset option. Any assistance would be greatly appreciated.
