I’m running a Mandriva 2010.2 on my laptop. I’ve been trying to install the PGI trial version compiler (in my home directory) , but when I run makelocalrc with the command :
Sorry you are having problems. First thing to determine is whether
you have gcc for 32-bit and 64-bit installed. They are needed for
PGI compilers to use the same assembler and linker as gcc, and a
successful installation begins with the PGI install script finding
gcc on your system.
