I have compiled gstreamer 1.6 on my TK1 developer board as I would like to use some of the Qt gstreamer sinks that are available with gstreamer 1.6. However, at the moment, I cannot use omxh264enc plugin. So, to enable that I tried to compile the gstomx from sources.
However, when I do so, I get the following errors:
gstomxvideoenc.c:67:6: error: 'NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop1in5' undeclared (first use in this function)
{NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop1in5,
gstomxvideoenc.c:69:6: error: 'NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop1in3' undeclared (first use in this function)
{NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop1in3,
gstomxvideoenc.c:71:6: error: 'NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop1in2' undeclared (first use in this function)
{NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop1in2,
gstomxvideoenc.c:73:6: error: 'NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop2in3' undeclared (first use in this function)
{NVX_ENCODE_VideoEncTemporalTradeoffLevel_Drop2in3,
gstomxvideoenc.c: In function 'gst_omx_video_enc_class_init':
gstomxvideoenc.c:187:42: error: 'NVX_ENCODE_VideoEncTemporalTradeoffLevel_DropNone' undeclared (first use in this function)
#define DEFAULT_TEMPORAL_TRADEOFF_TYPE NVX_ENCODE_VideoEncTemporalTradeoffLevel_DropNone
gstomxvideoenc.c:317:11: note: in expansion of macro 'DEFAULT_TEMPORAL_TRADEOFF_TYPE'
DEFAULT_TEMPORAL_TRADEOFF_TYPE,
gstomxvideoenc.c:319:11: warning: passing argument 5 of 'g_param_spec_enum' makes integer from pointer without a cast [enabled by default]
GST_PARAM_MUTABLE_READY));
In file included from /usr/include/glib-2.0/glib-object.h:28:0,
from /usr/include/gstreamer-1.0/gst/gstenumtypes.h:7,
from /usr/include/gstreamer-1.0/gst/gst.h:31,
from gstomxvideoenc.c:26:
/usr/include/glib-2.0/gobject/gparamspecs.h:1055:13: note: expected 'gint' but argument is of type 'const struct GEnumValue *'
GParamSpec* g_param_spec_enum (const gchar *name,
gstomxvideoenc.c: In function 'gst_omx_video_enc_init':
gstomxvideoenc.c:375:29: note: in expansion of macro 'DEFAULT_TEMPORAL_TRADEOFF_TYPE'
self->temporal_tradeoff = DEFAULT_TEMPORAL_TRADEOFF_TYPE;
gstomxvideoenc.c:375:27: warning: assignment makes integer from pointer without a cast [enabled by default]
gstomxvideoenc.c: In function 'gst_omx_video_enc_check_nvfeatures':
gstomxvideoenc.c:1406:5: error: unknown type name 'NVX_PARAM_USENVBUFFER'
NVX_PARAM_USENVBUFFER param;
gstomxvideoenc.c:1412:18: error: 'NVX_INDEX_CONFIG_USENVBUFFER' undeclared (first use in this function)
(char *) NVX_INDEX_CONFIG_USENVBUFFER, &eIndex);
In file included from gstomxvideoenc.h:29:0,
from gstomxvideoenc.c:30:
gstomx.h:68:7: error: request for member 'nSize' in something not a structure or union
(st)->nSize = sizeof (*(st)); \
gstomxvideoenc.c:1415:7: note: in expansion of macro 'GST_OMX_INIT_STRUCT'
GST_OMX_INIT_STRUCT (¶m);
gstomx.h:68:3: warning: statement with no effect [-Wunused-value]
gstomx.h:69:7: error: request for member 'nVersion' in something not a structure or union
(st)->nVersion.s.nVersionMajor = OMX_VERSION_MAJOR; \
gstomx.h:69:17: error: request for member 's' in something not a structure or union
gstomx.h:69:19: error: request for member 'nVersionMajor' in something not a structure or union
gstomx.h:69:3: warning: statement with no effect [-Wunused-value]
gstomx.h:70:7: error: request for member 'nVersion' in something not a structure or union
(st)->nVersion.s.nVersionMinor = OMX_VERSION_MINOR; \
gstomx.h:70:17: error: request for member 's' in something not a structure or union
gstomx.h:70:19: error: request for member 'nVersionMinor' in something not a structure or union
gstomx.h:70:3: warning: statement with no effect [-Wunused-value]
gstomx.h:71:7: error: request for member 'nVersion' in something not a structure or union
(st)->nVersion.s.nRevision = OMX_VERSION_REVISION; \
gstomx.h:71:17: error: request for member 's' in something not a structure or union
gstomx.h:71:19: error: request for member 'nRevision' in something not a structure or union
gstomx.h:71:3: warning: statement with no effect [-Wunused-value]
gstomx.h:72:7: error: request for member 'nVersion' in something not a structure or union
(st)->nVersion.s.nStep = OMX_VERSION_STEP; \
gstomx.h:72:17: error: request for member 's' in something not a structure or union
gstomx.h:72:19: error: request for member 'nStep' in something not a structure or union
gstomx.h:72:3: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c:1416:12: error: request for member 'nPortIndex' in something not a structure or union
param.nPortIndex = self->enc_in_port->index;
gstomxvideoenc.c:1416:7: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c:1417:12: error: request for member 'bUseNvBuffer' in something not a structure or union
param.bUseNvBuffer = OMX_TRUE;
gstomxvideoenc.c:1417:7: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c: In function 'gst_omx_nvx_enc_set_property':
gstomxvideoenc.c:2383:3: error: unknown type name 'NVX_PARAM_VIDENCPROPERTY'
NVX_PARAM_VIDENCPROPERTY oEncodeProp;
gstomxvideoenc.c:2385:3: note: in expansion of macro 'GST_OMX_INIT_STRUCT'
GST_OMX_INIT_STRUCT (&oEncodeProp);
gstomxvideoenc.c:2386:14: error: request for member 'nPortIndex' in something not a structure or union
oEncodeProp.nPortIndex = self->enc_out_port->index;
gstomxvideoenc.c:2386:3: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c:2389:18: error: 'NVX_INDEX_PARAM_VIDEO_ENCODE_PROPERTY' undeclared (first use in this function)
(gpointer) NVX_INDEX_PARAM_VIDEO_ENCODE_PROPERTY, &eIndex);
gstomxvideoenc.c:2394:18: error: request for member 'bLowLatency' in something not a structure or union
oEncodeProp.bLowLatency = self->low_latency;
gstomxvideoenc.c:2394:7: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c:2395:18: error: request for member 'bSliceIntraRefreshEnable' in something not a structure or union
oEncodeProp.bSliceIntraRefreshEnable = self->SliceIntraRefreshEnable;
gstomxvideoenc.c:2395:7: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c:2396:18: error: request for member 'SliceIntraRefreshInterval' in something not a structure or union
oEncodeProp.SliceIntraRefreshInterval = self->SliceIntraRefreshInterval;
gstomxvideoenc.c:2396:7: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c:2397:18: error: request for member 'bBitBasedPacketization' in something not a structure or union
oEncodeProp.bBitBasedPacketization = self->bit_packetization;
gstomxvideoenc.c:2397:7: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c:2399:18: error: request for member 'nVirtualBufferSize' in something not a structure or union
oEncodeProp.nVirtualBufferSize =
gstomxvideoenc.c:2399:7: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c: In function 'gstomx_set_temporal_tradeoff':
gstomxvideoenc.c:2433:3: error: unknown type name 'NVX_CONFIG_TEMPORALTRADEOFF'
NVX_CONFIG_TEMPORALTRADEOFF oTemporalTradeOff;
gstomxvideoenc.c:2438:3: note: in expansion of macro 'GST_OMX_INIT_STRUCT'
GST_OMX_INIT_STRUCT (&oTemporalTradeOff);
gstomxvideoenc.c:2442:7: error: 'NVX_INDEX_CONFIG_VIDEO_ENCODE_TEMPORALTRADEOFF' undeclared (first use in this function)
NVX_INDEX_CONFIG_VIDEO_ENCODE_TEMPORALTRADEOFF, &eIndex);
gstomxvideoenc.c:2442:7: warning: passing argument 2 of 'gst_omx_component_get_index' discards 'const' qualifier from pointer target type [enabled by default]
gstomx.h:385:15: note: expected 'gpointer' but argument is of type 'const struct GEnumValue *'
OMX_ERRORTYPE gst_omx_component_get_index (GstOMXComponent * comp, gpointer str,
gstomxvideoenc.c:2447:20: error: request for member 'TemporalTradeOffLevel' in something not a structure or union
oTemporalTradeOff.TemporalTradeOffLevel = self->temporal_tradeoff;
gstomxvideoenc.c:2447:3: warning: statement with no effect [-Wunused-value]
gstomxvideoenc.c: At top level:
gstomxvideoenc.c:2352:1: warning: 'gst_omx_video_enc_set_Qfactor' defined but not used [-Wunused-function]
gst_omx_video_enc_set_Qfactor (GstOMXVideoEnc * self)
gstomxvideoenc.c:1359:1: warning: 'gst_omx_video_enc_reconfigure_output_port' defined but not used [-Wunused-function]
gst_omx_video_enc_reconfigure_output_port (GstOMXVideoEnc * self)
make[2]: *** [libgstomx_la-gstomxvideoenc.lo] Error 1
make[2]: Leaving directory `/home/ubuntu/gst_1.6.4/gstomx1_src/gst-omx1/omx'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/ubuntu/gst_1.6.4/gstomx1_src/gst-omx1'
make: *** [all] Error 2
Has anyone else encountered this? Any ideas on how I may resolve these errors?
