Hi.
Since Monday I am getting the following error when installing cuda-11-4 inside the container or in the host jetson.
# apt install cuda-11-4
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-11-4 : Depends: cuda-toolkit-11-4 (>= 11.4.14) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
With further investigation, I found that the cuda-profiler-api-11-4 is missing in the debian package manager. See:
# apt install cuda-libraries-dev-11-4
cuda-libraries-dev-11-4 : Depends: cuda-profiler-api-11-4 (>= 11.4.239) but it is not installable
And indeed I am not finding it in: Index (nvidia.com)
Thank you for any help.
