Reading package lists… Done
Building dependency tree
Reading state information… Done
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-dkms-455 (455.32.00-0ubuntu1) …
update-initramfs: deferring update (trigger activated)
A modprobe blacklist file has been created at /etc/modprobe.d to prevent Nouveau
from loading. This can be reverted by deleting the following file:
/etc/modprobe.d/nvidia-graphics-drivers.conf
A new initrd image has also been created. To revert, please regenerate your
initrd by running the following command after deleting the modprobe.d file:
/usr/sbin/initramfs -u
*** Reboot your computer and verify that the NVIDIA graphics driver can ***
*** be loaded. ***
INFO:Enable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
Removing old nvidia-455.32.00 DKMS files…
Deleting module version: 455.32.00
completely from the DKMS tree.
Done.
Loading new nvidia-455.32.00 DKMS files…
Building for 5.11.0-25-generic
Building for architecture x86_64
Building initial module for 5.11.0-25-generic
ERROR: Cannot create report: [Errno 17] File exists: ‘/var/crash/nvidia-kernel-source-455.0.crash’
Error! Bad return status for module build on kernel: 5.11.0-25-generic (x86_64)
Consult /var/lib/dkms/nvidia/455.32.00/build/make.log for more information.
dpkg: error processing package nvidia-dkms-455 (–configure):
installed nvidia-dkms-455 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of cuda-drivers-455:
cuda-drivers-455 depends on nvidia-dkms-455 (>= 455.32.00); however:
Package nvidia-dkms-455 is not configured yet.
dpkg: error processing package cuda-drivers-455 (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of cuda-drivers:
cuda-drivers depends on cuda-drivers-455 (= 455.32.00-1); however:
Package cuda-drivers-455 is not configured yet.
dpkg: error processing package cuda-drivers (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of nvidia-driver-455:
nvidia-driver-455 depends on nvidia-dkms-455 (= 455.32.00-0ubuntu1); however:
dpkg: error processing package nvidia-driver-455 (–configure):
dpkg: dependency problems prevent configuration of cuda-runtime-11-1:
cuda-runtime-11-1 depends on cuda-drivers (>= 455.32.00); however:
Package cuda-drivers is not configured yet.
dpkg: error processing package cuda-runtime-11-1 (–configure):
dpkg: dependency problems prevent configuration of cuda-demo-suite-11-1:
cuda-demo-suite-11-1 depends on cuda-runtime-11-1; however:
Package cuda-runtime-11-1 is not configured yet.
dpkg: error processing package cuda-demo-suite-11-1 (–configure):
dpkg: dependency problems prevent configuration of cuda-11-1:
cuda-11-1 depends on cuda-runtime-11-1 (>= 11.1.1); however:
cuda-11-1 depends on cuda-demo-suite-11-1 (>= 11.1.74); however:
Package cuda-demo-suite-11-1 is not configured yet.
dpkg: error processing package cuda-11-1 (–configure):
Processing triggers for initramfs-tools (0.136ubuntu6.6) …
update-initramfs: Generating /boot/initrd.img-5.11.0-25-generic
Errors were encountered while processing:
nvidia-dkms-455
cuda-drivers-455
cuda-drivers
nvidia-driver-455
cuda-runtime-11-1
cuda-11-1
E: Sub-process /usr/bin/dpkg returned an error code (1)
I am attaching the nvidia-bug-report.log (1.0 MB)
Also the /var/lib/dkms/nvidia/455.32.00/build/make.log (51.8 KB)
