Creating docker file which uses tltv3 dokcer image. But getting the following error while login into NGC docker registry
RUN /bin/sh -c 'docker login nvcr.io -u oauthtoken --password-stdin *****'
Error
"docker login" requires at most 1 argument.
See 'docker login --help'.
Usage: docker login [OPTIONS] [SERVER]
Log in to a Docker registry
Can docker login nvcr.io
work?
It won’t work for a non interactive device (inside docker file)
Can it work under interactive mode?
Its working on an interactive mode . But i have to use it for non interactive mode
Above should be -u $oauthtoken
yes, but it won’t help. Getting the same error even after adding that
Please use below way.
$ docker login --username=\$oauthtoken --password="yourkey" nvcr.io
system
closed
#9
