Check the .yaml file and find where the checkpoint is.
Then rename it.
I read this section but where I have to make changes I am not getting
This my .yaml file:
output_dir: /root/getting_started_v4.0.1/notebooks/tao_launcher_starter_kit/action_recognition_net/actionrecognitionnet/rgb_3d_ptm
encryption_key: cXQ5NTRwMnU0YzNlMXNxNzEyNmkyb2JoMHE6ODVhMDJlMDctZTg1OC00ZmJiLThmMTUtOGVhN2Y3YTRmMmRl
model_config:
model_type: rgb
backbone: resnet18
rgb_seq_length: 3
input_type: 3d
sample_strategy: consecutive
dropout_ratio: 0.0
train_config:
optim:
lr: 0.001
momentum: 0.9
weight_decay: 0.0001
lr_scheduler: MultiStep
lr_steps: [5, 15, 20]
lr_decay: 0.1
epochs: 20
checkpoint_interval: 1
dataset_config:
train_dataset_dir: /root/getting_started_v4.0.1/notebooks/tao_launcher_starter_kit/action_recognition_net/data/actionrecognitionnet/train
val_dataset_dir: /root/getting_started_v4.0.1/notebooks/tao_launcher_starter_kit/action_recognition_net/data/actionrecognitionnet/test
label_map:
fall_floor: 0
ride_bike: 1
output_shape:
- 224
- 224
batch_size: 32
workers: 8
clips_per_video: 5
augmentation_config:
train_crop_type: no_crop
horizontal_flip_prob: 0.5
rgb_input_mean: [0.5]
rgb_input_std: [0.5]
val_center_crop: False
there is no ‘=’ sign.
please help me out
Is it
yess
How about running with
!tao action_recognition train
-e $SPECS_DIR/train_rgb_3d_finetune.yaml
-r $RESULTS_DIR/rgb_3d_ptm
-k $KEY
I will try this and get back to you if i get the same error
Also, please share the full command you run previously.
Above screenshot does not show the full command.
