Hardware - GPU - NVIDIA RTX 3090
Hardware - CPU - Intel(R) Core™ i9-10900X CPU @ 3.70GHz
Operating System - Ubuntu 20.04
Riva Version -2.3.0
Able to run bash riva_init.sh
Getting error when running bash riva_start.sh
Below is the riva init log file
riva_init_log.txt (6.5 KB)
Below is the error picture
And even modified the config.sh file by going through the similar topics which are mentioned previously, attaching the modified config file below
config.sh (14.1 KB)
I had to clean and re-init riva to solve this when it happened to me.
V
Thanks for your reply, but I even tried that too, its the same again
Hi @manjunathkondamu
Thanks for your interest in Riva
Apologies for the delay
Thanks for sharing the the config and riva_init logs
Thanks @vanessa.crosby for the suggestions
Have one request,
when running the riva_start.sh, Kindly request to open another instance/terminal,
Run the below command
docker logs riva-speech
and share the output as txt file in this thread (collecting the output at end or last will be helpful)
Hi @rvinobha
Thank for your reply
As you mentioned it, i have run the command and took the both stderr and stdout into one log file,
Command : sudo docker logs riva-speech &>! logs.txt
below is the attached log file
logs.txt (44.8 KB)
I am getting the same issue, how did you solved it?
Didn’t solve it at, waiting for the reply
I cleaned up the environment and it worked.
bash riva_clean.sh
Thanks for the suggestion, but I did try the same and the results were same.
We suggest you to install Update/install Nvidia Driver Version - 510+
Current Driver Installation from logs - 470
Please update the driver, run bash riva_clean.sh and try again, and let us know if it works
Please find the support matrix link below for reference
https://docs.nvidia.com/deeplearning/riva/user-guide/docs/support-matrix.html
Thanks for your patience
