- Getting error command not found while using this command on deepstream-l4t 6.0-triton container
gst-inspect-1.0 nvinferserver
- Getting this error while running this command :
Error - ** ERROR: <create_multi_source_bin:1423>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1516>: create_multi_source_bin failed
** ERROR: <create_pipeline:1323>: create_pipeline failed
** ERROR: main:639: Failed to create pipeline
Quitting
App run failed
Command - deepstream-app -c /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app-triton/source1_primary_classifier.txt
This looks like Deepstream related. We are moving this post to Deepstream forum to get better help.
Thank you.
mchi
6
Could you provide your setup info as below?
• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version : 6.0
• TensorRT Version : 8.01
• NVIDIA GPU Driver Version (valid for GPU only) : 470.57.02
Hardware : Jetson Xavier NX
a. GPU: 384 core NVIDIA Volta GPU with 48 Tensor Cores
b. HW config, CPU, RAM : 6 core NVIDIA Carmel ARM v8.2 64-bit CPU, 8GB RAM
Deepstream Version: 6.0
Tensorrt version: 8.01
Nvidia gpu driver: Jetpack 4.6
Docker container: deepstream-l4t6.0-triton
mchi
8
I can’t reproduce this issue. I believe this is a setup issue.
Could you re-flash your Jetson-NX with Jetpack4.6 and try again?
