Hardware Platform: [DRIVE AGX Pegasus™ Developer Kit]
Software Version: [DRIVE Software 10]
Host Machine Version: [Ubuntu 18.04]
SDK Manager Version: [1.3.1.7110]
Oct’20 - Hi, When i fllow the basic tutorials:
mkdir build
cd build
cmake -DCMAKE_BUILD_TYPE=Release /path/to/driveworks/samples/folder
make -j
I meet fatal error: X11/Xcursor/Xcursor.h: No such file or directory at make -j. How can i do with this?
VickNV
October 20, 2020, 1:23pm
#3
Hi @wangmingen ,
Are you referring to /usr/local/driveworks/doc/nvsdk_html/dwx_samples_building_x86.html in your host system (after installing DRIVE Software 10)?
For DRIVE Software 10, “/path/to/driveworks/samples/folder” is at “/usr/local/driveworks/samples”. You should run below command.
$ cmake -DCMAKE_BUILD_TYPE=Release /usr/local/driveworks/samples
Hi,VickNV,
Thanks for your reply,
Yes, i have installed DRIVE Software 10 and executed this command, but the error is still here.
VickNV
October 21, 2020, 1:52pm
#5
Do you see the same issue on other host systems?
Please run below commands and provide all the log for our checking. Thanks!
$ cmake -DCMAKE_VERBOSE_MAKEFILE:BOOL=ON -DCMAKE_BUILD_TYPE=Release /usr/local/driveworks/samples
$ make
I executed the commands,
$ cmake -DCMAKE_VERBOSE_MAKEFILE:BOOL=ON -DCMAKE_BUILD_TYPE=RELEASE /usr/local/driveworks/samples
CMake Warning at cmake/SamplesSetBuildType.cmake:15 (message):
CMAKE_BUILD_TYPE must be one of (Debug|Release). Using Release as default.
Call Stack (most recent call first):
CMakeLists.txt:9 (include)
-- Could NOT find EGL (missing: EGL_LIBRARY EGL_INCLUDE_DIR)
-- Building with TRT version and cudnn version 7.5.1.14
-- Building GLFW for X11 (static)
-- Driveworks Samples install dir: /home/wang/build/install
-- Found Driveworks
-- Configuring done
-- Generating done
-- Build files have been written to: /home/wang/build
$ make
/usr/bin/cmake -H/usr/local/driveworks/samples -B/home/wang/build --check-build-system CMakeFiles/Makefile.cmake 0
/usr/bin/cmake -E cmake_progress_start /home/wang/build/CMakeFiles /home/wang/build/CMakeFiles/progress.marks
make -f CMakeFiles/Makefile2 all
make[1]: 进入目录“/home/wang/build”
make -f CMakeFiles/update_cuda_deps.dir/build.make CMakeFiles/update_cuda_deps.dir/depend
make[2]: 进入目录“/home/wang/build”
cd /home/wang/build && /usr/bin/cmake -E cmake_depends “Unix Makefiles” /usr/local/driveworks/samples /usr/local/driveworks/samples /home/wang/build /home/wang/build /home/wang/build/CMakeFiles/update_cuda_deps.dir/DependInfo.cmake --color=
make[2]: 离开目录“/home/wang/build”
make -f CMakeFiles/update_cuda_deps.dir/build.make CMakeFiles/update_cuda_deps.dir/build
[ 1%] Dependencies for /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.stamp
cd /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir && /usr/bin/cmake -D verbose:BOOL=1 \ -D build_configuration:STRING=Release -P /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o_deps.cmake
– Generating dependency file: /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.NVCC-depend
/usr/local/cuda/bin/nvcc -M -D__CUDACC__ /usr/local/driveworks/samples/src/imageprocessing/stereo/stereo/utils.cu -o /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.NVCC-depend -ccbin /usr/bin/c++ -m64 -DLINUX -DLINUX -Xcompiler ,"-gsplit-dwarf","-Werror","-Wall","-Wunused","-Wunused-value","-Wunused-parameter","-O3","-DNDEBUG" -arch=sm_30 -lineinfo -std=c++11 -DNVCC -I/usr/local/cuda/include -I/usr/local/cuda/include -I/usr/include -I/home/wang/build/configured -I/usr/local/driveworks-2.2/targets/x86_64-Linux/include -I/home/wang/build/configured/samples
– Generating temporary cmake readable file: /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.tmp
/usr/bin/cmake -D input_file:FILEPATH=/home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.NVCC-depend -D output_file:FILEPATH=/home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.tmp -P /usr/local/driveworks/samples/cmake/FindCUDA/make2cmake.cmake
– Copy if different /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.tmp to /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend
/usr/bin/cmake -E copy_if_different /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.tmp /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend
– Removing /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.tmp and /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.NVCC-depend
/usr/bin/cmake -E remove /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.tmp /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.NVCC-depend
– Updating timestamp /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.stamp
/usr/bin/cmake -E touch /home/wang/build/src/imageprocessing/stereo/stereo/CMakeFiles/sample_stereo_disparity.dir//gen_utils.cu.o.depend.stamp
[ 2%] Dependencies for /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.stamp
cd /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir && /usr/bin/cmake -D verbose:BOOL=1 \ -D build_configuration:STRING=Release -P /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o_deps.cmake
– Generating dependency file: /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.NVCC-depend
/usr/local/cuda/bin/nvcc -M -D__CUDACC__ /usr/local/driveworks/samples/src/image/image_common/utils.cu -o /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.NVCC-depend -ccbin /usr/bin/c++ -m64 -DLINUX -DLINUX -Xcompiler ,"-gsplit-dwarf","-Werror","-Wall","-Wunused","-Wunused-value","-Wunused-parameter","-O3","-DNDEBUG" -arch=sm_30 -lineinfo -std=c++11 -DNVCC -I/usr/local/cuda/include -I/usr/local/cuda/include -I/usr/include -I/home/wang/build/configured -I/usr/local/driveworks-2.2/targets/x86_64-Linux/include -I/home/wang/build/configured/samples
– Generating temporary cmake readable file: /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.tmp
/usr/bin/cmake -D input_file:FILEPATH=/home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.NVCC-depend -D output_file:FILEPATH=/home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.tmp -P /usr/local/driveworks/samples/cmake/FindCUDA/make2cmake.cmake
– Copy if different /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.tmp to /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend
/usr/bin/cmake -E copy_if_different /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.tmp /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend
– Removing /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.tmp and /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.NVCC-depend
/usr/bin/cmake -E remove /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.tmp /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.NVCC-depend
– Updating timestamp /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.stamp
/usr/bin/cmake -E touch /home/wang/build/src/image/image_common/CMakeFiles/dw_samples_image_common.dir//gen_utils.cu.o.depend.stamp
[ 2%] Built target update_cuda_deps
make -f 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/build.make 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/depend
cd /home/wang/build && /usr/bin/cmake -E cmake_depends “Unix Makefiles” /usr/local/driveworks/samples /usr/local/driveworks/samples/3rdparty/src/lodepng /home/wang/build /home/wang/build/3rdparty/src/lodepng /home/wang/build/3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/DependInfo.cmake --color=
make -f 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/build.make 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/build
[ 2%] Building CXX object 3rdparty/src/lodepng/CMakeFiles/lodepng-src.dir/src/lodepng.cpp.o
cd /home/wang/build/3rdparty/src/lodepng && /usr/bin/c++ -DLINUX -I/usr/local/cuda/include -I/home/wang/build/configured -I/usr/local/driveworks/samples/3rdparty/src/lodepng/include -gsplit-dwarf -Werror -Wall -Wunused -Wunused-value -Wunused-parameter -O3 -DNDEBUG -fPIC -std=gnu++14 -o CMakeFiles/lodepng-src.dir/src/lodepng.cpp.o -c /usr/local/driveworks/samples/3rdparty/src/lodepng/src/lodepng.cpp
[ 3%] Linking CXX static library liblodepng-src.a
cd /home/wang/build/3rdparty/src/lodepng && /usr/bin/cmake -P CMakeFiles/lodepng-src.dir/cmake_clean_target.cmake
cd /home/wang/build/3rdparty/src/lodepng && /usr/bin/cmake -E cmake_link_script CMakeFiles/lodepng-src.dir/link.txt --verbose=1
/usr/bin/ar qc liblodepng-src.a CMakeFiles/lodepng-src.dir/src/lodepng.cpp.o
/usr/bin/ranlib liblodepng-src.a
[ 3%] Built target lodepng-src
make -f 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/build.make 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/depend
cd /home/wang/build && /usr/bin/cmake -E cmake_depends “Unix Makefiles” /usr/local/driveworks/samples /usr/local/driveworks/samples/3rdparty/src/glfw /home/wang/build /home/wang/build/3rdparty/src/glfw /home/wang/build/3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/DependInfo.cmake --color=
make -f 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/build.make 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/build
[ 4%] Building C object 3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/context.c.o
cd /home/wang/build/3rdparty/src/glfw && /usr/bin/cc -DLINUX -D_GLFW_USE_CONFIG_H -I/usr/local/cuda/include -I/home/wang/build/configured -I/usr/local/driveworks/samples/3rdparty/src/glfw/3.2-screen/src/…/include -I/home/wang/build/3rdparty/src/glfw/3.2-screen/src/x11 -gsplit-dwarf -O3 -DNDEBUG -fPIC -Wall -Wp,-w -std=gnu11 -o CMakeFiles/glfw-x11.dir/3.2-screen/src/context.c.o -c /usr/local/driveworks/samples/3rdparty/src/glfw/3.2-screen/src/context.c
In file included from /usr/local/driveworks/samples/3rdparty/src/glfw/3.2-screen/src/internal.h:163:0,
from /usr/local/driveworks/samples/3rdparty/src/glfw/3.2-screen/src/context.c:28:
/usr/local/driveworks/samples/3rdparty/src/glfw/3.2-screen/src/x11_platform.h:39:10: fatal error: X11/Xcursor/Xcursor.h: 没有那个文件或目录
#include <X11/Xcursor/Xcursor.h>
compilation terminated.
3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/build.make:65: recipe for target ‘3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/context.c.o’ failed
make[2]: *** [3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/3.2-screen/src/context.c.o] Error 1
CMakeFiles/Makefile2:221: recipe for target ‘3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/all’ failed
make[1]: *** [3rdparty/src/glfw/CMakeFiles/glfw-x11.dir/all] Error 2
make[1]: 离开目录“/home/wang/build”
Makefile:132: recipe for target ‘all’ failed
make: *** [all] Error 2
hi, I installed libgles2-mesa-dev and reinstalled xrog-dev.
these solved the error
thank u for your support
VickNV
October 22, 2020, 3:45am
#8
Thanks for letting us know~
Here is the related document (from /usr/local/driveworks/doc/nvsdk_html/dwx_devguide_getting_started.html on the host system with DRIVE Software installed):
