Executing the SetAnimCurveKeys command for a new CurveNode when a PushGraph prim already exists causes an error. Tested on both Kit 107.3 and 108 and error only occurs in 108. See below for example.
Yes this is confirmed also by myself. This is a bad bug. I have immediately reported this to the engineers. I will try to get a response and a work around asap. Thanks for letting me know.
As a workaround, you can duplicate the first ‘CurveNode’, change its name, and assign a new prim on its properties.
Yes, but it is definitely broken. We have filed a bug and we are already on it. Thank you for pointing this out.
