I’m trying to build the ssdCaffe on PX2 AutoChauffeur (P2379); CUDA version 9.2; OpenCV 2.4.9.1.
Followed the instruction gived by http://caffe.berkeleyvision.org/installation.html
cp Makefile.config.example Makefile.config
# Adjust Makefile.config (for example, if using Anaconda Python, or if cuDNN is desired)
make all
make test
make runtest
make all & make test passed. make runtest gave the error:
[ RUN ] CPUBBoxUtilTest.TestOutputBBox
F1114 03:18:11.846827 9387 test_bbox_util.cpp:279] Check failed: out_bbox.xmax() == 50. (50 vs. 50)
*** Check failure stack trace: ***
@ 0x7f815a8718 google::LogMessage::Fail()
@ 0x7f815aa614 google::LogMessage::SendToLog()
@ 0x7f815a8290 google::LogMessage::Flush()
@ 0x7f815aaeb4 google::LogMessageFatal::~LogMessageFatal()
@ 0x6ac440 caffe::CPUBBoxUtilTest_TestOutputBBox_Test::TestBody()
@ 0xa1b01c testing::internal::HandleExceptionsInMethodIfSupported<>()
@ 0xa142c4 testing::Test::Run()
@ 0xa14400 testing::TestInfo::Run()
@ 0xa144c0 testing::TestCase::Run()
@ 0xa15620 testing::internal::UnitTestImpl::RunAllTests()
@ 0xa15934 testing::UnitTest::Run()
@ 0x530e28 main
@ 0x7f802cc8a0 __libc_start_main
Makefile:526: recipe for target 'runtest' failed
make: *** [runtest] Aborted (core dumped)
I am guessing can this be solved by modify the Makefile? Because I found a similar error occurred on Jetson https://devtalk.nvidia.com/default/topic/1025057/jetson-tx2/can-t-build-the-single-shot-detector-ssd-/. But our compilation environment are quite different, so I’m here searching for help.
Thanks in advance!
