Example cases from v22.09
Hello, its great to see the new update in v23 of modulus. I remember in v22.09 there were example cases of heat transfer etc that helped understand how to code in this environment. Does the new version have similar example or can we use the previous examples?
Hi @mitanshtrip
The examples are present in the Github repo now. If you are wanting to use version 22.09 then its a simple update of the imports in these example scripts. In other words, follow the migration guide in reverse. APIs are consistent between the versions.
