Hi, I am trying to get wall velocity gradients for my problem. However, it doesn’t seem to work.
Previously, I followed the example in the conjugate heat transfer problem for v22.03. I insert:
# add inferencer
inferencer = PointwiseInferencer(
geo.sample_boundary(4000, parameterization=pr),
["u__x", "u__y", "u__z",
"v__x", "v__y", "v__z",
"w__x", "w__y", "w__z"],
nodes=flow_nodes,
flow_domain.add_inferencer(inferencer, "inf_data")
into the orginial code and it worked.
However, now using v22.09, it doesn’t work anymore. The error is:
root@5533d3a0b1f7:/myprojects/three_fin_3d# python three_fin_flow.py
[06:59:25] - JIT using the NVFuser TorchScript backend
[06:59:25] - JitManager: {'_enabled': True, '_arch_mode': <JitArchMode.ONLY_ACTIVATION: 1>, '_use_nvfuser': True, '_autograd_nodes': False}
[06:59:25] - GraphManager: {'_func_arch': False, '_debug': False, '_func_arch_allow_partial_hessian': True}
Error executing job with overrides: []
File "three_fin_flow.py", line 254, in run
AttributeError: 'ThreeFin' object has no attribute 'sample_boundary'
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
Is there a bug somewhere?
