I am looking at the introductory example to test the use of Modulus here.
Am I suppose to run anything else in the terminal before pasting the commands listed under “Creating Nodes”?
Hi @nazia.aslam
This example is showing code snippets from the LDC Python script in the examples repo. You should be running this python file using the command at the bottom of the webpage you linked.
Understood. Thank you!
