Hello I am trying to install the modulus extension on Create 2022.1.3, I am running Ubuntu 22.04 with a 3080Ti grapics card. Driver version 510.73.05 CUDA version 11.6
After clicking on the install button this is the output of the Create console before it crashes.
2022-06-17 20:37:22 [169,667ms] [Info] [omni.kit.app.plugin] [169.741s] Async pulling extension: modulus_ext.core-22.3.1 from the registry.
2022-06-17 20:37:22 [169,667ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: [kit/public] pull extension: modulus_ext.core-22.3.1+lx64.r.cp37 in ‘/home/waverider/.local/share/ov/data/Kit/Create.Next/2022.1/exts/3’
2022-06-17 20:37:22 [169,667ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: [kit/public] modulus_ext.core-22.3.1+lx64.r.cp37 is not in cache: ‘/home/waverider/.cache/ov/exts/3’
2022-06-17 20:37:22 [169,668ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: (find archive) check exists, omni.client.stat: https://kit-103-0-public-extensions.s3.amazonaws.com/public/3/archives/modulus_ext.core-22.3.1+lx64.r.cp37.zip
2022-06-17 20:37:22 [169,670ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: result: Result.OK
2022-06-17 20:37:22 [169,670ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: downloading: ‘https://kit-103-0-public-extensions.s3.amazonaws.com/public/3/archives/modulus_ext.core-22.3.1+lx64.r.cp37.zip’ → ‘/tmp/tmp2pe7fm0p/modulus_ext.core-22.3.1+lx64.r.cp37.zip’…
2022-06-17 20:37:22 [169,670ms] [Info] [omni.kit.app.impl] [py stdout]: [omni.kit.registry.nucleus]: [omni.kit.registry.nucleus]: downloading: ‘https://kit-103-0-public-extensions.s3.amazonaws.com/public/3/archives/modulus_ext.core-22.3.1+lx64.r.cp37.zip’ → ‘/tmp/tmp2pe7fm0p/modulus_ext.core-22.3.1+lx64.r.cp37.zip’…
2022-06-17 20:37:22 [169,670ms] [Info] [omni.kit.registry.nucleus.utils] [omni.kit.registry.nucleus]: (downloading ext archive) copying: https://kit-103-0-public-extensions.s3.amazonaws.com/public/3/archives/modulus_ext.core-22.3.1+lx64.r.cp37.zip → /tmp/tmp2pe7fm0p/modulus_ext.core-22.3.1+lx64.r.cp37.zip
Thank you!
