@esteban.lahoz - I am not sure what the issue is at the moment (thanks for the logs). The logs show an unusual condition, can you please get me some files that were created at the crash? Files should be at
C:/Omniverse/data/Kit/Create.Next/2021.3/
Example: you might see three such .dmp files
C:/Omniverse/data/Kit/Create.Next/2021.3\e8f7f505-3660-4912-95c7-1566e58001fc.dmp
There is possibility of a corrupted install at some point. So one idea is to un-install Omniverse and reinstall. There is a tool for this that you need to use.
Hi, I uninstalled everything, used the cleanup tool and reinstalled Omniverse from scratch to my C:.
It installed successfully, so perhaps it needs it on the main drive.
The error appears if I manage the installation, as well as the use of the software from a remote PC. If I install or use Omniverse from the computer in Local, all problems are solved and works perfectly.
I hope it is solved after the beta, because I can not use Omniverse it in my AWS instances.
22:37:34.086 › Using proxy server SOMEPROXYSERVER:8080 for the main process.
22:37:35.701 › Waiting for authentication…
22:37:35.702 › Scheduling installer…
22:37:35.873 › FetchError: request to https://launcher-index-prod.s3.amazonaws.com/components/create/versions.json failed, reason: read ECONNRESET
at ClientRequest. (/tmp/.mount_omniveTVMCFJ/resources/app.asar/dist/main.js:38:26676)
at ClientRequest.emit (events.js:315:20)
at TLSSocket.socketErrorListener (_http_client.js:426:9)
at TLSSocket.emit (events.js:315:20)
at emitErrorNT (internal/streams/destroy.js:92:8)
at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
at processTicksAndRejections (internal/process/task_queues.js:84:21)
22:37:35.874 › Error occurred in handler for ‘prepare-install’: FetchError: request to https://launcher-index-prod.s3.amazonaws.com/components/create/versions.json failed, reason: read ECONNRESET
