The error happens when calling create_camera_sensor()I am using Ubuntu 20.04, Python 3.7.0 and have this error.
I also have this error, and I’m using Ubuntu 22.04, Python3.8 with pytorch1.10+cuda11.3
Related topics
| cudaImportExternalMemory failed on rgbImage | 7 | 2677 | June 28, 2024 | |
| Create camera sensor fail on buffer | 4 | 3121 | August 28, 2021 | |
| cudaExternamMemoryGetMappedBuffer failed when creating camera IsaacGym | 0 | 157 | March 1, 2025 | |
| gymapi.Gym.create_camera_sensor() cause errors on multi-gpu server | 2 | 1135 | March 1, 2025 | |
| Invalid device ordinal error when running example code interop_torch.py with CUDA_VISIBLE_DEVICES set | 1 | 915 | January 5, 2024 | |
| Running PyTorch on Jetson TX2 | 9 | 1619 | February 27, 2024 | |
| Import torch error Jetson TX2 | 1 | 779 | October 23, 2020 | |
| Gym cuda error: no kernel image is available for execution on the device | 21 | 5086 | July 15, 2024 | |
| Installing pytorch - /usr/local/cuda/lib64/libcudnn.so: error adding symbols: File in wrong format collect2: error: ld returned 1 exit status | 19 | 5853 | February 25, 2022 | |
| Import External Memory fail | 0 | 804 | November 29, 2019 |
