Exchange M2M_ALERT and M2E_ALERT
I’m designing our base board for NX module. We don’t need the M.2 E slot but want to use SDMMC1. I have several questions:
  1. Can SDMMC1 be used alone without using M.2 Key E slot?
  2. If the answer of Q1 is OK. Because SDIO_D1 is shared with M2M_ALERT (NVMe), if I want to use both SDMMC1 and NVMe, I must assign M2M_ALERT to another gpio, right? As I don’t need M.2 Key E slot, may I assign it to GPIO10?
  3. Then what we should do to the driver?
We’re checking this issue internally, will update once clarified. Thanks
We think the M2M_ALERT# is just a GPIO pin and left for sw developer over m2e to use it as part of sideband signalling as they wish.
Its not a mandatory requirement to use this pin. Our driver also not uses this on our devkit.
If you wants to use it, you can find our GPIO for it.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
