I’ve been accessing the Expansion Header tool on my Jetson AGX Orin no problem for the last few months, but today it stopped working.
I ran “sudo /opt/nvidia/jetson-io/jetson-io.py” to access it, then enabled PWM on pins 15 and 18. I saved the configuration and selected the option to “Exit without rebooting.” I then rebooted the machine a few minutes later and tried to get a PWM output out of pins 15 and 18, but to no avail. So I attempted to open the expansion header tool again. But now, when I run “sudo /opt/nvidia/jetson-io/jetson-io.py”, the tool pops up briefly and then closes. So PWM is not enabled properly on pins 15 and 18 and I can’t open the header tool to try and re-enable them. I should also clarify that I had PWM running fine on pins 15 and 18 earlier today, but disabled them to test something else. Any help is much appreciated, thank you!
