I’m using the Jetson AGX Orin development kit and I flashed it with Nvidia SDK manager, Jetpack 5.0.2, and L4T R35.1.Using the Pinmux spreadsheet, I converted the GPIO pins to I2S2 and flashed the device. So, I’d like to know whether those pins had any effect. According to Jetson wiki, the Jetson-io.py code can be used to verify the J40 Header pin.
the issue is I’m not able to see the UI for the Jetson-io.py. I’ve attached a video for reference.
I never see this issue with JP-5.0.2, I’m also able to enable Jetson-IO on the latest release.
since JP-5.1 is now available, could you please download the latest release and have double confirmation.
thanks
