For Ethernet connectivity to an external FPGA, are you expecting developers to use RoCE to move data or something else?
For Ethernet connectivity to an external FPGA on the Jetson AGX Orin, developers have a few options to move data. While RoCE (RDMA over Converged Ethernet) is one possible solution, it’s not the only one. Here’s a comprehensive overview of the options:
- RoCE (RDMA over Converged Ethernet): RoCE is a protocol that allows for remote direct memory access (RDMA) over Ethernet networks. It enables low-latency, high-bandwidth data transfer between devices. However, RoCE requires specific hardware support, and not all Ethernet controllers or FPGAs may support it.
- TCP/IP or UDP: Traditional TCP/IP or UDP protocols can be used for Ethernet connectivity between the Jetson AGX Orin and an external FPGA. This approach is widely supported, but it may not offer the same level of performance as RoCE or other specialized protocols.
- PCIe: If the FPGA is connected to the Jetson AGX Orin via a PCIe interface, developers can use the PCIe protocol to transfer data between the devices. This approach offers high-bandwidth, low-latency data transfer, but it requires a PCIe connection between the devices.
- Custom protocols or APIs: Depending on the specific requirements of the application, developers may choose to implement custom protocols or APIs for data transfer between the Jetson AGX Orin and the external FPGA. This approach can offer optimized performance and flexibility, but it requires significant development effort.
In comparison to other Jetson modules, the Jetson AGX Orin has a more comprehensive set of features and interfaces that can be used for Ethernet connectivity to an external FPGA. For example:
- The Jetson AGX Xavier series has a similar set of features and interfaces, but it may not offer the same level of performance as the Jetson AGX Orin.
- The Jetson Xavier NX series and Jetson Nano series have more limited features and interfaces, which may restrict the options for Ethernet connectivity to an external FPGA.
In summary, while RoCE is one possible solution for Ethernet connectivity to an external FPGA on the Jetson AGX Orin, it’s not the only option. Developers should consider the specific requirements of their application and choose the most suitable approach based on factors such as performance, latency, and complexity.
