Nvidia Jetson devboard with 2 ethernet connector
Hi all,
I am looking for an NVIDIA Jetson with 2 ethernet connectors. I found that Jetson AGX Orin Series has two ethernet (1x GbE, 1x 10GbE) but it seems to me the dev board does not have two ethernet connectors. Is it correct?
As an alternative, I thought to use, and I found it’s an used solution, an “ethernet to pcie adaptor”. Are there any adapters recommended?
Cheers
Eugenio
This category is for Enterprise Networking, your topic belongs in the Jetson forums. I will go ahead and move it over for you.
Yes, on devkit only GbE port is available. We have no recommendation on “ethernet to pcie adaptor”, hope someone has such experience can be shared, or you can check with some vendors in ecosystem first.
