My environment is Fedora 20 x86_64 running on a Lenovo W530 with nVidia K1000M graphics.
My usual setup has an IBM T221 monitor (“Big Bertha”, which can run at 3840x2400) connected via a short mini-display-port-to-DVI cable. I run the external monitor at 1920x1200 resolution.
I have usually installed kmod-nvidia-x.x.x from the rpmfusion repository, and updated kmod-nvidia at the same time as updating the kernel. (I only found out about the akmod-nvidia option recently.) But the problem described below is the same if I install kmod-nvidia, akmod-nvidia, or download the NVIDIA-Linux-xxxx.run installation script.
This configuration all worked well until “recently”, with the T221 correctly detected, and X running perfectly at 1920x1200. But possibly since a recent upgrade or two (I have been living with the problem for a few weeks) the external monitor is not detected correctly. It is detected as present, but X attempts to run at 5760x1080 (where the native W530 resolution is 1920x1080). As 1920x1080 is not a resolution supported by the T221, I get nothing on the monitor. When I run nvidia-setings, the screen layout seems to be “1920x1080 (the laptop screen), a 1920x1080 blank, and another 1920x1080 screen (the monitor)”
The standard nouveau driver correctly displays on the external monitor, so it is not a connectivity issue.
I haven’t had the chance to roll back kernel and driver levels to see if I can find out when the rot set in.
Is it possible that a recent change to the driver has caused this issue?
I should stress that I am not an expert in X and drivers, so please use short words!
And something I found, xrandr output looks strange, previously I did not have that many outputs… and VGA is not connected…
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 8192 x 8192
VGA-0 connected (normal left inverted right x axis y axis)
1920x1080 59.93 + 40.09
LVDS-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 345mm x 194mm
1920x1080 59.93*+ 40.09
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
DP-6 disconnected (normal left inverted right x axis y axis)
kernel:
Linux localhost.localdomain 3.17.4-200.fc20.x86_64 #1 SMP Fri Nov 21 23:26:41 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Any one, any idea ? Really bad bug, I can’t connect my notebook to external displays… (auch).
Thanks in advance ! (an other Peter M --> funny :D)
