Nvidia 410.73 Extend Monitor Can Not Be Detected
Helllo all,
I’ve a little problem about my Nvidia Graphics Drivers. I cannot see any extend monitor on the nvidia-settings.
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080     60.02 +  60.01*   59.97    59.96    59.93    48.03
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1600x900      59.99    59.94    59.95    59.82
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1280x800      59.99    59.97    59.81    59.91
   1152x864      60.00
   1280x720      60.00    59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
HDMI-1-3 disconnected (normal left inverted right x axis y axis)
inxi -GS
System:    Host: caglar-G5-5587 Kernel: 4.15.0-39-generic x86_64 bits: 64 Desktop: Gnome 3.28.3
           Distro: Ubuntu 18.04.1 LTS
Graphics:  Card-1: Intel Device 3e9b
           Card-2: NVIDIA GP106M [GeForce GTX 1060 Mobile]
           Display Server: x11 (X.Org 1.19.6 ) driver: nvidia Resolution: 1920x1080@60.01hz
           OpenGL: renderer: GeForce GTX 1060 with Max-Q Design/PCIe/SSE2 version: 4.6.0 NVIDIA 410.73
Please post the output of
sudo cat /sys/module/nvidia_drm/parameters/modeset
It’s just say Y
Y
Please run
grep modeset /etc/modprobe.d/*
and
grep modeset /lib/modprobe.d/*
to find the file which contains
options nvidia-drm modeset=1
and change it to
options nvidia-drm modeset=0
then run
sudo update-initramfs -u
and reboot.
should return ‘N’ if done right.
Check if the external monitor is available.
Unfortunately you will get tearing afterwards.
Thank you so much.
And yes, the output is N
So the external monitor now is detected? Did this previously work with an earlier driver?
Yes, the external monitor now is detected.
Not exactly, I cannot say that my old driver did that. Because it was working properly, but I’ve a lot of fan noise when I was using the driver 390. So I decided to upgrade 410 LTS using graphics-drivers/ppa channel. After that, everything messed up. I cannot login using UI once even my password was correct. I’ve spend two days for fixing problems with googling. Yesterday I get this point. It was a really bad nightmare for me.
