Extended monitors not working. Now one monitor is super wide and the other is not displaying
Hi I’m working on Ubuntu 20.04. I have an RTX 2080 and GTX 1080 and I usually have two screens connected to each, one through DVI and the other HDMI. Usually works fine and I can usually extend screens via the display settings. However, since moving and setting my workstation up again, it detected my screen but wouldn’t display one of them. I tried to use the X-server to enable screens and selected twin display. Now one screen is super wide (beyond the dims) and the other is still not showing.
This is the output of xrand:
xrandr --query
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
USB-C-0 disconnected (normal left inverted right x axis y axis)
DVI-D-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected primary (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94 50.00 60.00 50.04
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x960 60.00
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
I’m abit of a novice and would love some help. Thanks
