When building multi-camera vision systems on Jetson Orin NX or Orin Nano, synchronization quickly becomes one of the most important challenges.
For applications such as:
Robotics
Intelligent Transportation Systems (ITS)
Smart surveillance
Industrial automation
Multi-camera AI perception
even small timing differences between cameras can impact sensor fusion, object tracking, depth estimation, and overall perception accuracy.
We’ve worked on external trigger-based camera synchronization for Jetson Orin NX and Orin Nano and recently documented the implementation approach here:
The article focuses on hardware-triggered synchronization and discusses practical considerations for achieving synchronized image capture across multiple cameras on Jetson platforms.
I’m curious to hear how others are approaching synchronization in their deployments:
Are you using hardware triggers or software timestamp alignment?
What synchronization accuracy is required for your application?
Have you encountered challenges with latency or frame alignment?
How does synchronization scale as camera count increases?
Are you using PTP or other synchronization methods in distributed systems?
Would be great to hear real-world experiences and lessons learned from the community.
