How does Nvidia propose we do camera frame synchronization between multipole cameras? Many embedded systems expose a FSYNC or frame sync pin but I see no mention of this in any of the documentation.
hello daniel174,
please download MMAPI package to obtain the sources. $ sudo apt install nvidia-l4t-jetson-multimedia-api
there’re Argus samples for demonstration.
for example, /usr/src/jetson_multimedia_api/argus/samples/syncSensor or syncStereo.
you may see-also similar discussion threads, such as Topic 1070823 for reference.
thanks
Both of those examples show how to process synchronized images, but they do not show how to design the hardware to synchronize the images in the first place. How does NVIDIA recommend designing the camera modules and carrier board to achieve this?
normally, there’ll be FSYNC pin for frame synchronization. this is hardware pin for two camera module for outputting frames simultaneously. you may also contact with Jetson Camera Partners for camera solutions.
Is there a FSYNC pin on the Nvidia module?
hello daniel174,
we don’t have reference camera module with FSYNC so far.
you may see-also this technical blog, Selecting the Right Camera for the NVIDIA Jetson and Other Embedded Systems | NVIDIA Technical Blog.
