I’m curious if from running the command jtop in the command line (monitors and shows power for the jetson nano) I can extract the Power/mW through some sort of python script?
I also know there is the tegrastats command as well which would be useful but I’m still not too sure how to extract something from that command.
Again I would like to do this in python- ideally I want to save motion detection values in an excel file but also store Power consumption in that excel file as well. So far I have been able to store thermal temperature in the excel file using ‘/sys/class/----/----0/temp1_input’. Can I somehow get some kind of power consumption or that exact number from jtop of Power/mW?
Thank you this helps and I’m able to get to something like ‘/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_current0_input’ which prints out a value. For some reason in the script the value is not updating? It stays the same.
Im running this:
with open('/sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/in_current0_input') as t:
current = ((t.read()))
print(current)
