Power consumption monitoring
I am trying to monitor power consumption of jetson nano using TEGRASTATS.I want to know what exactly is shown in tegrastats specilly POM_5V_IN,POM_5V_GPU and POM_5V_CPU.I also want to know what Integrated power consumption monitoring tool is used on jetson nano.
RAM 1698/3965MB (lfb 99x4MB) CPU [16%@921,10%@921,10%@921,11%@921] EMC_FREQ 0% GR3D_FREQ 0% PLL@32.5C CPU@36C PMIC@100C GPU@33.5C AO@42.5C thermal@34.75C POM_5V_IN 2915/2915 POM_5V_GPU 40/40 POM_5V_CPU 319/319
Hi thohtdelta,
Please refer to the details in [url]Welcome — Jetson Linux<br/>Developer Guide 34.1 documentation
<VDD_name> X/Y
<VDD_name> is power consumption (mW) for certain module “name”'s rail. X is current value and Y is average value.
This is same for POM_5V_name.
Thanks kayccc
I tried to save the data from tegrastats and ended up saving the whole line.
It will be helpful if i can only save the power and temperature,please tell me where do tegrastats take those values from(like a file?),if so tell me the path.
Hi thohtdelta,
Install the strace package:
apt install strace
Output used files:
strace tegrastats 2>&1 | grep openat | grep sys
You will get something like that:
openat(AT_FDCWD, “/sys/bus/i2c/devices/6-0040/iio_device/rail_name_0”, O_RDONLY) = 4
openat(AT_FDCWD, “/sys/bus/i2c/devices/6-0040/iio_device/in_power0_input”, O_RDONLY) = 4
openat(AT_FDCWD, “/sys/devices/virtual/thermal/thermal_zone1/temp”, O_RDONLY) = 4
openat(AT_FDCWD, “/sys/devices/virtual/thermal/thermal_zone1/type”, O_RDONLY) = 4
Ctrl+C for drop
The file /sys/bus/i2c/devices/6-0040/iio_device/in_power0_input is current POM_5V_IN value
The file /sys/devices/virtual/thermal/thermal_zone1/temp is current CPU-therm value
and so on (/sys/devices/virtual/thermal/thermal_zone1/type is a sensor type as you understood)
That was helpful @fedormelexin,
I also wanted to know one more thing
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2FAppendixTegraStats.html%23wwpID0E0SB0HA
After checking this link i am still confused whether POM_5V_IN is the total power consumed by the whole board or we need to ADD all the three likePOM_5V_IN+POM_5V_GPU+POM_5V_CPU to get the total power consumed the motherboard.
This is the reading we got while the strip camera was running
This is the reading we got while running TensorRT
RAM 3100/3957MB (lfb 18x1MB) SWAP 535/4096MB (cached 22MB) IRAM 0/252kB(lfb 252kB) CPU [79%@1428,100%@1428,81%@1428,83%@1428] EMC_FREQ 22%@1600 GR3D_FREQ 99%@844 APE 25 PLL@44.5C CPU@48.5C PMIC@100C GPU@43.5C  AO@51C thermal@46C POM_5V_IN 7700/4490 POM_5V_GPU 2408/523 POM_5V_CPU 1224/613
This sums up to more than 11 watts and sometimes even 13 watts ,thus my doubt.
Is this normal? Will this affect the board if it runs for a long time??
I do not know which option is correct.
Supply 4 Amps at 5 Volts through the Barrel Jack connector is 5V*4A = 20 Watts (MAX). 13 watts seems to be acceptable consumption.
With sufficient cooling, the runs for a long time should not affect the board.
POM_5V_IN measures the overall 5V input to the board, it represents the total power consumption. You don’t need to add POM_5V_GPU and POM_5V_CPU to it. The GPU/CPU rails are provided for extra reference.
Just an observation:
Jetson Nano without any peripherals with full CPU (no GPU) load seems to consume aroung 4.5W.
@nanom Could you please share what monitoring tool/setup do you use on your screenshot?
Not sure, but it might be jtop:
Hi @damian.bucha,
yes the monitor is jtop (shared from @Honey_Patouceul)
jtop from release 2.0 have fix the issue in this topic.
Now from jetson nano show properly the total power consumption (in bold POM_5V_IN)
Best,
Raffaello
Thank you very much for the info. I will check it out right away :)
